      06-20-2016, 09:02 AM   #1
z4m_06
S54 - Vanos Unit Questions
Hi all - hoping to gain some knowledge regarding the Vanos issue for our cars.
- Does anyone have experience with the Dr. Vanos upgrade for our cars? If so, can you please elaborate?
- When is the right time to think about getting the Dr. Vanos upgrade? I can barely hear any metallic clicking noises (however some rattle does exist around 2,700 - 3,500 rpm) - no where close to the videos on youtube though. Currently have 72k miles on the car
Thanks!
      06-20-2016, 10:09 AM   #2
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Which specific Dr. Vanos upgrade(s) are you referring to? I've done the Beisan upgrade (Vanos exhaust oil pump disc with smaller hole for hub), rattle kit, and seal kits. I don't hear the metallic marble noises around 2800 rpm anymore. Not sure what caused that noise (the slack between vanos disc and hub or the excess play on the splined shaft), but it's super quiet now after the upgrade. I did it mainly for the peace of mind of minimizing the hub tab failure than anything else - all the others were "while we're in there" sort of things to do.
I had skipped the solenoid upgrade because that can be easily replaced if and when it failed.
While doing the job, I found that the upper chain guide was already in bad shape at only around 44K miles, so looks like only a 50K-mile replacement item
For more pictures of my upgrade, see this => http://www.zpost.com/forums/showpost...&postcount=730
      06-20-2016, 10:40 AM   #3
TexasZed4MC
TexasZed4MC's Avatar
Drives: 2006 Interlagos Z4 M Coupe
I just completed the COMPLETE Dr. Vanos replacement system on my M Coupe. All new Cryo exhaust cam , anti-rattle kit, bolts, oil pump. everything ....
A vanos can go at anytime. after talking with them several times I wanted it all done at one time and never have to worry about it again.
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor
      06-20-2016, 10:54 AM   #4
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
WHS
The rattle at ~3k rpm is caused from too much play between the oil pump disk holes and the exhaust hub tabs. Read this
      06-20-2016, 01:18 PM   #5
z4m_06
Thanks for the info - certainly very helpful. Did you do the process yourself or utilize a shop? Can you let me know how much this cost?
Thanks!
      06-20-2016, 01:19 PM   #6
z4m_06
Hey TexasZed4MC - what made you do the entire upgrade? Peace of mind? Or was there something in particular going on with your car? Can you let me know how much the whole procedure cost you in total?
      06-20-2016, 01:41 PM   #7
TexasZed4MC
I was getting a rattle, pretty sure the oil pump part, the car has 80k on it and maybe a 100 track miles. The left side upper timing chain guide had broken also.
I wanted a complete peace of mind on the car.
It cost me $2,600 for everything plus the install.
      06-20-2016, 02:10 PM   #8
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
Thanks!
You've got PM'ed
      06-20-2016, 02:14 PM   #9
z4m_06
Thanks for the info, appreciate it.
      06-20-2016, 03:54 PM   #10
StickMon
StickMon's Avatar
Drives: 2006 MR
I broke an exhaust hub tab at about 90k miles and replaced it with the Dr. V "C300".
$850
I put in a Dr. V rebuilt Vanos at about 117k since my upper chain guide was toast and I figured if I was going to take the Vanos off, I might as well put a rebuilt on.
$1400
      06-20-2016, 10:31 PM   #11
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
did you guys replace just the upper chain guide?
my indi is recommending to replace the whole (4 part) chain guide.. (still waiting for the damn guide to arrive )
Powered by
      06-20-2016, 11:48 PM   #12
StickMon
StickMon's Avatar
Drives: 2006 MR
The top one has the tensioner pushing on the back side of it, and that's the part that wears, not the side the chain runs across.
Go figure.
If the cost isn't too bad, might as well go for all 4. You get a timing cover reseal out of it.
      06-21-2016, 12:52 AM   #13
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
^^^ Pretty much WHS
      06-21-2016, 10:26 PM   #14
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Its around 100us for all 4 bits.. so not too bad.. maybe hes doing it for insurance if the engine is open, nothing worse than having to wait for parts..
      06-22-2016, 01:11 PM   #15
StickMon
StickMon's Avatar
Drives: 2006 MR
Yea, the guides themselves are dirt cheap.
It's the labor that's nuts. Just the top one requires pulling the Vanos and exhaust hub.
Doing the others requires removing the timing cover.
Not sure how to do that, but I wouldn't be surprised if it involves first taking off the bumper cover and then keep taking things off until you hit block.
      06-22-2016, 04:12 PM   #16
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
The oil pan needs removal from what I gather. Some say you can get out without removing oil pan. I think this job with rod bearing replacement since oil pan is dropped.
Tags
dr vanos, roadster, vanos, z4m
