      02-19-2013, 11:29 AM   #1
usaz4mcr8cr
usaz4mcr8cr's Avatar
13
Drives: Z4MC
Oil leak, Head Gasket?
Installed euro headers and cats over the weekend and noticed an oil leak.
What do you guys think?
(Picture is from under the car, passenger side, looking up)
      02-19-2013, 01:40 PM   #2
NYZ4Jack
Drives: 2005 Z4 3.0i
If its a slow oil leak, it can be the all common, oil pump gasket leak. easy fix - just time consuming to get to the part.
      02-19-2013, 06:24 PM   #3
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
Your Constant Pressure Valve (CPV) is in that area. It's a pretty common leak after the Buna-N o-ring gets brittle. If oil is leaking down between the engine and transmission that's probably it. Do a google search or look on M3Forum for some fixes. With the headers removed, replacing the o-ring would be simple. I would try to get a hold of a Viton o-ring to replace it though.
      02-19-2013, 06:46 PM   #4
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
Initially I was also gonna suggest the CPV, however you can see it in the pic and its not leaking.
CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights
      02-19-2013, 06:56 PM   #5
bignosejim
bignosejim's Avatar
I thought that threaded hole in the block was for the CPV but wanted to mention it anyway.
OP, it could also be valve cover gasket or oil return pipe that connects to the valve cover. Make sure both copper crush washers are between the banjo bolt.
      02-19-2013, 06:59 PM   #6
Jumbosock
Jumbosock's Avatar
76
Is there any oil above where the headers mount? Any coming from under the top plastic cover?
      02-19-2013, 07:13 PM   #7
O-cha
O-cha's Avatar
218
Drives: Mcoupe
I'm not trying to be a dick here, but, can people who have no idea what they are looking at not chime in so confidently? It's definitely neither of these.
From the looks of the picture it's more likely a valve cover gasket leak, but it's not that easy to tell from a picture.
      02-19-2013, 10:21 PM   #8
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
Is the head oily at all, above the exhaust ports? Might help to determine if it's the valve cover gasket or not.
<img src=http://i284.photobucket.com/albums/ll30/onebluemcm/RG63_08-1-1.jpg border=0 alt= />
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=|
Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo)
RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint
      02-28-2013, 01:44 AM   #9
usaz4mcr8cr
13
Drives: Z4MC
Dropped the car off at the Crevier BMW to have the oil leak looked at. They were unable to source it so they cleaned the motor and drove it for a couple of miles. Their conclusion is that there is no leak but informed me that I should keep an eye on it. If it resurfaces I should bring it back. I sure hope it doesn't.
Thanks for all the input guys. I'll keep my fingers crossed.
On a side note, the euro headers and cats are amazing. My only complaint is that with my RE Diablos, the setup is a little loud. I hope to get used to the decibel increase otherwise might have to find a different set of cans.
