11-23-2012, 05:18 AM | #23 |
Rep 753
I have the 4-pot kit all around with Brembo LCF 600+ fluid, Hawk DTC-60 pads up front and HT-10s out back- love the setup. Better brake feel, modulation, cooling and lower pedal pressure.
Front weights: |
12-11-2012, 11:24 AM | #25 |
Rep 5,329
4pots are more than enough imo!!!
02-12-2013, 07:36 AM | #27 |
Rep 1,031
I am on stock wheels for winter with the 6/4 setup. In the front you need a 12.5mm spacer. The rear is fine. I have camber plates and am lowered slightly so I don't rub as bad as others might with stock wheels but there are a few times I can hear some rubbing in corners.
02-13-2013, 07:05 AM | #28 | |
@rspinajr
Rep 25
02-14-2013, 03:01 AM | #29 |
Rep 912
Anyone heard or using XYZ brakes? http://www.xyz-racing.com/
It's a racing BBK and i reckon it's pretty high quality. My friend has an HPF stage 2 M3 and that BBK can hold the car down like nothing else. we haven't tested brake fade under track conditions but these XYZ brakes seems to be used in competition racing. I am thinking of purchasing the 355x32 6POT all around BBK brakes. |
02-14-2013, 07:07 AM | #30 |
Rep 503
Drives: Z4 M Coupe
A friend has a 330mm 6 piston XYZ kit on the front of his Audi TT 2.0t but doesn't actually uses them in anger.. They look decent quality for the money though.
02-14-2013, 08:21 AM | #33 |
Rep 503
Drives: Z4 M Coupe
In Europe it's about €1500 for the front 6pot 355mm kit. Not sure about North American pricing...
02-14-2013, 10:17 AM | #34 |
Rep 1,100
02-14-2013, 10:55 AM | #35 |
Rep 912
02-14-2013, 11:04 AM | #36 |
Rep 1,100
thanks. Looking for a BBK kit for my Z4 (non M coupe) I dont need crazy performance as the car is my daily. I will probably need to change the brakes along with the calipers soon so I am looking at my option. Car has over 105k on it.
02-16-2013, 08:54 PM | #37 |
Rep 1,031
02-21-2013, 03:23 AM | #38 |
tosser
31
Rep 988
our oem brakes are good, but why couldn't bmwM give us the stuff they're putting in their cars now :/ aren't 135i brakes like 6pot or something. eesh
'07 MCoupe lots of mods |
02-21-2013, 01:11 PM | #39 |
enthusiast
48
Rep 1,695
If you need brake pads for your stop techs, check out the FS thread. 30% off and only used for 1 track day. The famous PFC 01's
http://www.zpost.com/forums/showthread.php?t=805462 |
04-17-2013, 07:12 PM | #41 |
Rep 4,726
The stoptechs are great, can't recommend them enough. At least on my car, they are perfectly balanced and bring the whole car down when threshold braking. If you really want a set PM me.
04-18-2013, 07:31 PM | #42 |
#dubspec
6336
Rep 5,201
Rear yes, front might be close to fitting without a spacer. My 14" 6/4 stoptech kit fits with a 10mm spacer up front. I'm having some new tires fitted tomorrow and actually mounted the stock wheels with the spacer so I could bring my wheels in.
04-19-2013, 04:38 PM | #43 |
#dubspec
6336
Rep 5,201
04-20-2013, 01:20 AM | #44 |
Rep 503
Drives: Z4 M Coupe
Your car looks spotless! Stoptechs round the looks off brilliantly.
