      04-25-2015, 03:31 PM   #1
SwissArmy
Why so serious?
SwissArmy's Avatar
How to attach AC Schnitzer Spoiler?
Hello
I have the below spoiler. I tried 3M automotive mounting tape and it doesn't feel like it would hold. Is there some sort of silicone or adhesive you guys could recommend for a clean and solid bond?
Thanks!
      04-27-2015, 07:15 AM   #2
Beedub
bmw themselves use BETAlink but be careful that stuff is nasty..
      04-27-2015, 09:38 AM   #3
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
+1 for BETAlink, my OEM CF spoiler was put on with that stuff. And yes it is nasty stuff, if you're going to use it be careful what you put it on.
      04-27-2015, 09:45 AM   #4
Beedub
whatever you attach with BETAlink will need to be damaged to remove, that stuff is serious!
      04-28-2015, 03:52 PM   #5
DreamTheater
Drives: E85 Z4
Yep, something like that should hold it on.
I forgot what I attached mine with but I got a tube of it from the local hardware store for $20 because the BETAlink that came with mine had turned to a solid after sitting for 7ish years.
When applying it have plenty of paper towel or something to clean up excess, it will get messy, very messy.
I also used tape to hold it down firmly against the boot while it dried to prevent it from moving.
