10-22-2013, 10:33 PM | #1 |
1621
Rep 4,294
Ordered H&R 29119 Springs for coupe
Hi, well I finally got around to ordering the springs for my coupe. Delivery is two weeks. So hopefully they arrive before my car is out of the shop. If not I will be doing the install myself and re getting an alignment afterwards.
Any tips, tricks or any input on the install? Any info is appreciated. Cheers
Powered by |
10-22-2013, 11:47 PM | #2 |
Rep 1,001
Nice pick up; you are going to like it. Anyhow, do search for DIY on Z4M. There are some really nice writeups from those swapped out theirs (sorry, i would do it for you but i am on my crabby iphone).
Youu will want to put about 500 miles for the springs to settle before do an alignment. Also, make sure the alignment shop put weight on the driver side during the alignment process (i believe about 150lbs.) Good luck. It is a very easy job! |
10-22-2013, 11:52 PM | #3 |
Rep 516
spring install is very easy. I used e46 install, only difference is the front shock assembly. Our front is more like a e36 i believe. Definetly get a friend to help. makes thing way easier.
10-23-2013, 12:35 AM | #4 |
1621
Rep 4,294
Also guys, I am initially going to be using my old shocks, until I can get the missus to approve some new bilsteins, what model would be a good compliment for these springs?
Obviously I'd like them as cheap as possible. ; )
Powered by |
10-23-2013, 12:39 AM | #5 | |
1621
Rep 4,294
Sir, you flatter me!
Powered by |
10-23-2013, 01:36 AM | #6 |
Rep 516
konis
10-23-2013, 10:29 AM | #7 |
Rep 1,001
10-23-2013, 12:26 PM | #8 |
Rep 370
Drives: 2007 BMW Z4MC
Garage List 2007 BMW Z4MC - Sold [7.66]
2006 330ci ZHP [0.00] 2000 Porsche Boxster S [0.00] 1972 DeTomaso Pantera [9.50] |
Please take some before / after picts. I'd like to see the effect and measurements. I've read that without the rear spacer, you will be a little "front high"...
[SIGPIC][/SIGPIC]
10-23-2013, 01:37 PM | #9 |
1621
Rep 4,294
Hopefully someone here will be able to pipe in on that? Rear spacer? Never heard of that???!
I2ical, which koni's?
Powered by |
10-23-2013, 02:55 PM | #10 |
Rep 1,739
Drives: 2008 Z4MC
You'll need these --> http://www.turnermotorsport.com/p-42...pair-15mm.aspx
They level things out nicely |
10-23-2013, 03:10 PM | #11 |
Rep 1,351
Drives: in Anger.
I have the same springs and I didn't use pads. Nor am I riding front high. But still running stock shocks and they are working just fine.
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs 1217/1815 !!! BOILER UP !!! |
10-23-2013, 04:05 PM | #12 |
Rep 924
My opinion on the H&Rs is that it barely lowers the front, and lowers the rear to satisfaction WITHOUT pads. With pads, the car is barely lowered. I don't mind a little rear squat.
10-23-2013, 04:09 PM | #13 | |
Rep 370
[SIGPIC][/SIGPIC]
10-23-2013, 10:02 PM | #14 |
1621
Rep 4,294
Hmm... Not sure, I haven't heard of many peeps applying the spacers, otherwise I would have heard of it before. Strange as the h&r site says it drops both front and rear by 25 mills.. There are other ones available that drop by 30 mills (diff part number) if you add a 15mill spacer that leave only a drop of 10 mills???
10-23-2013, 10:23 PM | #16 | |
Rep 7,408
10-24-2013, 12:32 AM | #17 |
1621
Rep 4,294
ok guys, just to sort this out, can some of you post a few pics who dont have rear spring pads installed, and just confirming we have the same H&R springs (29119-1).. i am getting rather frustrated here as with international shipping to dxb, those extra big spring pads will set me back another 100 US... so not really that happy atm..
id like to see some side on shots with and without the spring pads.. i will be staying on the stock 228 rims, so 18's all round.
Powered by |
10-24-2013, 06:26 PM | #18 |
Rep 924
without pads
10-24-2013, 06:30 PM | #19 |
Rep 924
If you're picking up the tab, I'm sure OP would also.
10-24-2013, 08:36 PM | #20 |
1621
Rep 4,294
Anyone know what the standart thickness is of the original spring pad?
Ok it's 5mm at the rear. Aes, yup no cash tree in my backyard. Nice pic too : ) Last edited by Vanne; 10-24-2013 at 09:03 PM.. |
10-26-2013, 01:14 PM | #21 |
1621
Rep 4,294
question about the bilstein struts, there are sport and there are the HD struts, i think the HD struts are the only ones designed for the z4m/c, but it mentions that they are for stock springs.. will these be suitable for my H&R lowering springs?
http://www.turnermotorsport.com/p-15...-4-shocks.aspx cheers
Powered by |
10-26-2013, 07:24 PM | #22 | |
Rep 1,739
Drives: 2008 Z4MC
