01-09-2012, 08:53 AM | #1 |
Rep 1,107
Blower motor....not blowing
All the HVAC controls/lights are functioning as usual it's just that there is no sign of life from the blower fan on the way to the office this morning. I restarted the car a few times when I got to the office but no change in behavior. Couldn't find any previous threads on a similar problem.
I was going to start with looking for a blown fuse. Anyone know what fuse# I would start with, and then what a good troubleshooting process from there on would be? (relays, etc...) Thanks in advance. (anyone know how accessible the blower motor is?) |
01-09-2012, 09:17 AM | #2 |
Rep 69
Here is one..http://www.zpost.com/forums/showthread.php?t=271321
seems they could be different for different years and possibly different countries |
01-09-2012, 10:51 AM | #4 |
Rep 1,107
Thanks for the tip on the FSR. I also see it referred to as the FSU and the Blower Motor Resistor. Has anyone changed one on an e85/e86? How long will it take? I can only find one DIY for the Z4 and it's on Bimmerfest which I can't access at work. I wonder if there is any way to determine if it's the FSR before just throwing a part at the problem?
Or, does anyone have access to their TIS now who could possibly look and find out what kind of a job this is? I was able to access that Bimmerfest post, but it didn't have any info other than the poster saying that the FSR on a Z4 seems more difficult to access on other BMW's. Last edited by elerner61; 01-09-2012 at 01:51 PM.. |
01-10-2012, 07:20 AM | #5 |
Rep 1,107
So, from the TIS it also seems to have another name: the "Heater-AC/Fan Controller". To get at it, the center vent, radio (to release a hold) and then the glove box and panel containing knee airbag have to come off.
Maybe if it was spring/summer or if I had a warmer garage, I would attempt it. Problem is with me, things tend to break when I'm futzing around to get things off and the parts are cold. Think I'll bring it to my local shop (probably $225 to install a $60 part, ticks me off a little) |
01-10-2012, 01:02 PM | #7 |
Rep 1,107
01-10-2012, 03:11 PM | #8 |
Rep 1,107
Question: In the fusebox, #57 is for the "Heated Blower" from what I can tell. Is that a relay? Fuse? Can I test it with a multimeter for continuity, since it's not a standard fuse?
Thx. |
01-10-2012, 05:48 PM | #9 | |
Rep 4,057
by the way, I hope it was clear that I was trying to inject a chuckle, through a play on words, into a serious chat, and not trying to make light of your concern. I would be quite upset to have any issue with my car. As a semi-related comment, during the summer, a chap posting here with an automatic transmission and paddle shifter equipped Z4 eventually found out that the fan motor or the resistor's failure was somehow causing his paddle shifters not to work. Clearly, the wiring of these cars , regardless of transmission option, is not simple. cheers,
Huz-Z
01-11-2012, 02:25 PM | #10 | |
Rep 1,107
Oh, and those larger relays/fuses in the fusebox? They are MAXI large format blade fuses. I pulled the one for the "Heated Blower" last night, the two fuses for Heater/Air Conditioner as well as disconnected the battery for 30 seconds just to do "everything I could" to try and fix the problem. I can understand high technology items failing, but a hvac blower? Pain in the ass. |
01-11-2012, 06:55 PM | #11 | |
Rep 421
01-12-2012, 08:36 PM | #12 |
Rep 1,107
I heard back from my shop around 3pm today. It's a blown Final Stage Resistor/Final Stage Unit/Blower Motor Resistor. They're getting the part tomorrow.
01-12-2012, 10:24 PM | #14 |
Rep 1,107
I didn't ask (figured if I fall on the floor, it would have better affect in front of him then over the phone). On the high side it could be 2 hours labor plus the part and tax...that's $400 in these parts.
This is only my second dealing with him. First was inspection 1 stuff including valve adjustments. He's not cheap, but he's a bimmer specialist with around 25 years or so experience. I'd rather keep him in business than feed the dealer's pockets. |
01-14-2012, 05:29 AM | #16 |
Rep 2,138
Drives: Me
BMW = Bring Money Withyou....
If you remember this, everything falls into place.... |
05-04-2018, 08:53 PM | #18 |
Rep 820
Drives: 2007 Z4MR silver grey
05-04-2018, 08:55 PM | #19 | |
Rep 820
05-04-2018, 10:26 PM | #20 |
Rep 1,107
