      05-26-2010, 12:08 AM   #1
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
Vibration at idle caused by loose engine bolts?
I have noticed over the last couple of days that I feel a little vibration when sitting at stop lights with the clutch in. Almost feels like a miss but I cannot hear any missing or gauge any movement on the tach. Cant feel any vibration at speed or when going around corners. Going to try and check out the mounting bolts tomorrow. Really have noticed it since header install. Related?
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      05-26-2010, 12:22 AM   #2
cloud8r
Member BMW CCA Los Angeles
cloud8r's Avatar
Drives: 2022 M8 GC Comp
2018 BMW M4  [0.00]
I've heard of some engine mount issues. Not sure if that would cause your type of issue though.
      05-26-2010, 01:43 AM   #3
shitbrownMcoupe
shitbrownMcoupe's Avatar
41
Drives: 2006 z4 M coupe
06 m coupe, beware... my bolts ripped off and valves bent.
      05-26-2010, 05:59 PM   #4
mousitch
Dark Sider
mousitch's Avatar
129
All bolts were torqued to spec. None were broke or loose at 24,500 miles.
      05-26-2010, 10:07 PM   #5
Nate2046
Nate2046's Avatar
16
Drives: '11 e92M
You're talking about two different things.
      05-26-2010, 10:28 PM   #6
mousitch
Dark Sider
mousitch's Avatar
129
After asking around I'm chalking the vibration up to the 1-3 header rubbing on a mounting bushing. After I was checking my engine mount bolts I noticed how close it was. Not sure if it can be moved away or not. NBD though. I can live with it.
      05-26-2010, 11:00 PM   #7
O-cha
O-cha's Avatar
218
Drives: Mcoupe
You have active headers, they aren't rubbing, that's ebay headers you're hearing about.
Unfortunately "vibration" is not enough to pinpoint anything.
