      05-17-2018, 07:40 PM   #1
Steeler
Steeler's Avatar
2429
Idle Hunting
So at a stop the idle hunts from maybe 700-900rpm. Regular idle is around 710-720rpm
This just started tonight.
What are the prime suspects?
No codes present.
      05-18-2018, 06:54 AM   #2
garz747
Drives: 07 Z4MC 01 330i 18 X3 M40i
Possible bad coil pack on one of the cylinders.
      05-18-2018, 06:37 PM   #3
StickMon
StickMon's Avatar
Drives: 2006 MR
Throttle position sensor?
I had that a while back.
Eventually gets weirder and weirder until it throws a code.
OH, and it might go into limp mode at start.
      05-30-2018, 06:53 PM   #4
henfjel
Drives: BMW E34 525ix
Eventually it will throw a code, but both of the above is easy to check and/or measure.
Maybe a vacuum leak?
      05-30-2018, 07:46 PM   #5
Steeler
Steeler's Avatar
2429
Quick update.
So the upstream O2 sensors are toast and took out my cats.
Time for metallic cats I guess
