06-13-2016, 04:20 PM | #1453 | |
Rep 1,017
Drives: 2010 E92 M3 6MT
Take a look at the WPC treated process and you will see, is reason I did not use a coated bearing due to less clearance.
4.4L LC stroker/ESS VT2-625/Volk te37 sl's/AA exhaust/DSS Carbon Fiber driveshaft/ARH Headers.. etc |
06-13-2016, 04:23 PM | #1454 |
Rep 1,174
You have been running Motul 5w40, correct?
06-13-2016, 04:35 PM | #1455 | |
Rep 362
06-13-2016, 04:37 PM | #1456 | ||
4-6-8
234
Rep 990
M3 E46 PY/Black
S2000 AP2 GPW/Tan Last edited by Sephiroth; 06-13-2016 at 04:43 PM.. |
06-13-2016, 04:53 PM | #1457 | |
Rep 24,684
I said several times on here that only time (future) will tell if replaced bearings would be better or not.. Well , here we have it ...I don't think this situation sounds positive ! After reading this I don't trust my S65 anymore... even not for one single minute anymore ! ///M-BMW...WTF is wrong with our motors ??? Man..I'm so sorry about your luck .
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
06-13-2016, 05:06 PM | #1458 | |
Rep 24,684
And that number is only 5-6 % of what happens worldwide ! Not even 20% of the Bimmerpost S65 owners post the bearing failure on here because they are thinking about the value of the car , and actually they are/were right.. Facts , panic posts ...What a joke .
06-13-2016, 05:10 PM | #1459 |
Rep 1,017
I ran motul 5w40 for the last 10k. 6k of those miles were HWY miles, was a road trip to california and back
06-13-2016, 05:59 PM | #1460 |
Captain Fatbelly
1423
Rep 1,994
Any idea how the wpc process affects oil analysis? It hardens an already hard bearing (as compared to lead babbitt bearings) so do you think maybe a uoa is pointless with these?
2013 c63 Amg coupe p31, v7 tune, plm headers, armytrix downpipes, EflexFuel
2008 dct coupe, evolve engine/dct tune, ttp, ms intake, megan exhaust, cf ds. Sold. |
06-13-2016, 06:00 PM | #1461 | ||
Rep 1,489
Thanks bruh. |
06-13-2016, 07:03 PM | #1462 | |
Rep 9,032
Any chance you can send an oil sample for that other oil analysis that Auto Talent sent off? Someone here had fuel dilution on their sample and that's all we've seen of that test they ran. .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
06-13-2016, 07:59 PM | #1463 |
Rep 1,017
I use blackstone, isn't that what they use? I dont have any oil from the previous change that I tested. Everything came back great though, no fuel or antifreeze/foreign matter in oil very low metal counts plently of addatives etc. Said was perfect report
06-13-2016, 08:00 PM | #1464 |
Rep 1,017
Sure thing man, if it can help someone else I got no problem with sharing. Will be intresting to see what the pictures look like.
06-13-2016, 08:49 PM | #1465 | |
Rep 9,032
http://www.m3post.com/forums/showthread.php?t=1233184 This one has a elevated fuel levels, as did a few M5's in the link above. http://www.m3post.com/forums/showthread.php?t=1268721 .
06-13-2016, 09:35 PM | #1466 |
Rep 2,527
Drives: 2011 M3/Porsche 992 GT3RS
Garage List 2024 Porsche 911 GT3RS [0.00]
2021 Porsche 718 Sp ... [0.00] 2021 Mazda Miata MX-5 [0.00] 2006 BMW M3 [0.00] 2011 BMW M3 [10.00] |
Your bearings were made from copper-lead? Horrible if so.
'06 BMW M3 ZCP 6MT | JRZ RS Pro + Hyperco 650/750 | Epic Tune | Brembo 355mm BBK | too many to list
'11 BMW M3 ZCP DCT | Akra Evolution | Eventuri intake | MCS 3-way | 4.6L Carbahn S65 | Zebulon Aero | AP Racing Radi-CAL BBK by Essex | 305/645-18 Pirelli DHB Porsche 992 GT3, 991.2 GT3RS, 718 Spyder instagram.com/titomanlio |
06-13-2016, 10:40 PM | #1467 |
Rep 1,017
My orignal bearings that I replaced at 31k were copper lead, most of those were down to copper. The WPC treated bearings I put in as replacements where the newer bearings that are Alum, my last oil sample only had Alum at 2.
Hopefully will get some pics of the bearings soon to see which ones failed.
06-13-2016, 10:53 PM | #1468 | |
4-6-8
234
Rep 990
06-14-2016, 10:18 AM | #1469 |
Rep 1,385
why people feel 5w40 is enough for a motor that operates at a 210 oil temp when not on it is beyond me. Even nissan recommends 20w50 in their sports car during hotter times. and the oil temps aren't as high as ours. the only place 5/40 helps would be on start up. after that when the motor is now hot that oil is like water.
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car |
06-14-2016, 11:49 AM | #1470 |
Rep 10,616
Whether with 0W40 or 10W60, oil will be around 210 most of the time. Maybe it is 10 degrees hotter with the thinner oil or 10 degrees cooler with the thicker oil. Only on the track or during the kind of hardcore driving I have not experienced in my 2 years with 0W40 (following 3 years with 10W60) might the oil cooler not keep up.
06-14-2016, 01:20 PM | #1471 |
Rep 1,017
Engine being torn down as we speak, sending block to VAC and having them work their magic. Hopefully block is viable and won't need to source one of those as well.
Will start a build thread once work out parts/build CR ratio etc. So far dealing with VAC has been nothing but a pleasure. Will be running 5w40 on the new stroker engine.
06-14-2016, 01:41 PM | #1472 | |
Rep 461
16 M4 / 17 C7 (Sold) / 08 E92 M3 AW (Sold) / 09 Yamaha R6 (Sold)
06-14-2016, 04:48 PM | #1473 | |
Captain Fatbelly
1423
Rep 1,994
06-14-2016, 06:56 PM | #1474 |
Rep 2,664
Drives: Goggomobil
This really sucks. The said failure could be due to a lot of things. However this is not awe inspiring! Sorry to hear.
F86 X6///
