      06-30-2015, 06:40 PM   #1
dorifto88
Drives: 88 Nissan Pathfinder
please help me interpret my dyno results (faloff in power above 6k)
-roughly 64k miles
-inspection 2 done last summer (~7k ago)
-rogue x pipe, cpi headers
-frank smith tune
-pulleys
-really, really hot today in sacramento (ask finnegan!)
im not (too) concerned about the (what i perceive to be a) lack of power, more concerned about the power after 6k. any thoughts would be greatly appreciated.
Michael
edit- granted the operator let off the throttle early but you can clearly see the curve was not going to recover and magically go above 250 whp
      06-30-2015, 06:51 PM   #2
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
I think it very well could've gone up higher still, and the operator should rev all the way up to fuel cut. All in all, I'm not sure why the dynos for this car have been on the lower side, since I recall your car being peppier than mine when they both were NA with slight bolt-ons :/
      07-01-2015, 12:19 AM   #3
seank
enthusiast
seank's Avatar
48
Do you usually go to the dyno when it is 107 degrees?
Most likely a weak fuel pump, assuming his foot was in it to redline.
      07-01-2015, 08:02 AM   #4
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
AFR still looks ok though. He should run it up to 8k rpm, unless he noticed a significant power loss or other issue at WOT.
      07-01-2015, 10:43 AM   #5
mfanatic325
///M-fanatic
Taiwan
193
BTW Mike, what section1 and mufflers are you currently running? Not that I think they're the issue here, but ughh...your car should be making more power
      07-01-2015, 03:48 PM   #6
Calichase
Drives: '07 s/c'd Z4MC '08 e82 '02 m3
Our stock ecus apparently stop fueling at 6500 according to Frank at ttfs.
Edit- seems that was stated above, and you have a tune which would eliminate that
      07-01-2015, 06:13 PM   #7
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
You should check out the Dyno thread from the E90 forum, lots of good information from a post started by Axiom.
http://www.e90post.com/forums/showthread.php?t=916863
What car is this? I or SI ? Either case the ECU does not cut fuel at 6500 RPM. Soft limiters start to kick in a bit higher.
      07-04-2015, 11:09 PM   #8
2282
OP has S54/M
