      02-12-2015, 06:54 AM   #1
JCF
Drives: 07 Z4 M Coupe
Steering wheel trim replacement real metal?
I've noticed that the trim on the steering wheel is starting to show signs of wear and was wondering if any enterprising vendors have considered making actual aluminum replacements that would match the rest of the aluminum trim?
I've seen posts on the forum where people have used plasti-dip, the massively overpriced carbon fiber trim replacements, and vinyl wrap. Anything else out there?
Can't find anything that is a middle ground. Replacing it with stock is about $200 for the same problem to crop up again, plasti-dip just seems like a temp fix to me.
      02-12-2015, 07:08 AM   #2
ZMCoupe
Drives: 2007 M Coupe
Have you looked into Hydro Dipping? A member on here did a few bits from his interior and they looked very nice. Also when done professionally the pieces are given a few coats of clear which should help the longevity...
Check out Liquid Carbon Shop to see some examples. There are also many different patterns and colours to choose from. I messaged them and I think it was $20 for small pieces so you can probably do it all for relatively cheap... At least less than half what the replacements would cost
      02-12-2015, 04:27 PM   #3
Steeler
Steeler's Avatar
2428
Carbon dip
http://www.zpost.com/forums/showthre...ight=dbarton62
      02-15-2015, 05:11 PM   #4
DanFromTucson
Drives: Z4 M Coupe
Do they have to be carbon-look? I would be happy with black. Mine are suffering from normal wear as well, so I'm definitely interested in any rehabilitation ideas.
      02-17-2015, 02:43 PM   #5
StickMon
StickMon's Avatar
Drives: 2006 MR
Maybe just strip off the rubber?
When I replaced my trim I carefully stripped the rubber coating off the button pods with Goof Off.
Nice and shiny black now. Doesn't quite match the trim, but no more scratches.
      02-17-2015, 04:20 PM   #6
JCF
Yeah that may be what I end up doing, but I was hoping an enterprising individual had come up with an alternate solution that was reasonable. 600 for real carbon fiber is too much and I'm not sold on hydro dipping being able to handle the abuse long term.
ECS sells OEM replacements for 170. Would love to have seen someone machine an aluminum solution for below 300. I'd buy it immediately.
      02-17-2015, 08:21 PM   #7
chickdr
Drives: 2006 M Roadster
You could buy the OEM spokes for the non M cars which are aluminum look like the door handles. I have considered doing this for the same reason you stated(contrast to match the aluminum dash). They seem to be clear coated rather the rubber coated stuff the M's have so would be more durable. The only issue is the bottom spoke as it must be trimmed to fit(it can be done though).
      02-17-2015, 09:40 PM   #8
MC 357
MC 357's Avatar
Armenia
16
Drives: R53 Cooper S/I3
Any DIY on how to remove the trim?
      02-17-2015, 10:05 PM   #9
RADRACR
RADRACR's Avatar
That OEM rubber coating stuff is such a fail. Unbelievable actually.
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts
'09 X5 35dSpace Grey / Saddle Brown
20" Forgestar F14 / SCR Delete
      02-17-2015, 10:47 PM   #10
dreamingat30fps
Drives: Miata, Cayenne, Model 3, F350
This. I did the same and looks 100x better than the peeling rubber.
      02-18-2015, 08:57 AM   #11
JCF
I think I have some CF di-noc laying around. Might try that as a challenge with all the weird angles.
      02-18-2015, 11:08 AM   #12
Steeler
Steeler's Avatar
2428
I tried this before dipping
Looked good for a month put inevitably lifted in the corners
      02-18-2015, 11:41 AM   #13
JCF
well crap. Thanks for saving me the time.
      02-18-2015, 01:17 PM   #14
antennahead
antennahead's Avatar
Drives: 2007 Z4MR silver grey
Replaced the crappy peeling rubber with a set of these, color is called graphite. Not sure if you can still find that color at the vendors, but the regular silver also looks good.
      02-18-2015, 02:17 PM   #15
JCF
yeah it may seem silly, but I like the little M-badge on the steering wheel. That's the only thing that is preventing me from ordering the silver trim pieces.
I'm also hunting around for a metal fabrication company here in Charlotte to see if they can make real aluminum trim pieces. I'm not optimistic on that but who knows.
      02-18-2015, 05:57 PM   #16
chickdr
I kind of agree, but one thought is to get the silver spokes for the horizontal spokes and leave the bottom one black.
      02-18-2015, 08:04 PM   #17
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6153
aluminum foil wrap?
If you have the time, it probably wouldn't be too hard to make a mold out of them, and then make some out of whatever you wanted. It only takes a couple minutes to take them off the steering wheel, 1 screw in the back of each piece and the two halves unsnap
now the challenging part would be the buttons, those have the same rubber coating and are a PITA to wrap. Heat staked in place so you can't take it apart either, at least not easily
another thing to note is that if you choose to wrap, surface imperfections will show through a bit, so it's a good idea to remove the rubber coating in any case
      02-19-2015, 06:37 AM   #18
JCF
Not looking to alter the buttons they're in perfect shape and yes they would be a giant PITA It's just the trim itself that has some scratches.
First step, regardless of the end solution, is to strip the rubber coating.
I'm wondering if some adhesive primer/activator would help prevent lifting of the corners with the dinoc
      02-20-2015, 11:37 PM   #19
AmmarYasirA
Ammar
AmmarYasirA's Avatar
Drives: a lot
I'm actually working on mine right now. Decided to diy but I'm having issues with paint and such..
I have mine completely taken apart and sanded down, painted once... But it was my first paint job and I didn't like it. Sanding it again and hopefully getting the paint right.
I'll kelp you guys updated and post a separate DIY soon.
2018 F150 Platinum - Black/Black - Leveled on 34's - DD
      03-22-2015, 08:20 PM   #20
AmmarYasirA
Ammar
Drives: a lot
just finished!
sorry for the crap quality. will take better pics soon
      03-22-2015, 09:50 PM   #21
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
I did mine when I first got the car... 2 years or so ago, I used matt black, turned out a treat..
both pics after refurb..
def one of the best DIY's if you ask me.
Powered by
