      09-25-2012, 10:51 PM   #1
22022
22022's Avatar
Drives: VT2-500 ZM4 roadster
Power steering line failure
Thought i would share this with you guys and gals, I had my expansion line fail ( part #3) right at the banjo bolt #6 on the tubing,There was no strain on the hose or tubing, nothing else was out of place,this maybe a weak spot on the part or just bad luck for me but it is something that probably should be checked during routine inspection. http://www.realoem.com/bmw/showparts...31&hg=32&fg=20
      09-26-2012, 03:28 AM   #2
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Dafuq?! Thanks for the heads up.
Curious if you happened to drive the car with no steering assistance? My MR2 (which was sold earlier this year) had manual steering and it actually felt really nice at the track. Wondering what our cars would feel like with manual steering
      09-26-2012, 06:40 AM   #3
chickdr
Drives: 2006 M Roadster
That is the first time I have seen a failure like that, but it is a known issue as far as weeping/leaks are concerned. Many folks have had that line replaced under warranty.
      09-26-2012, 10:56 PM   #4
22022
22022's Avatar
Yup I drove the car for a short distance around 2 or 3 right hand turns it was fairly hard, but nothing like my old falcon with armstrong steering.I would have driven it home if I knew I wouldn't f*ck up the pump.
      09-27-2012, 06:01 PM   #5
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
Any ideas on the Tischer cost for the replacement hose ?
      09-27-2012, 06:48 PM   #6
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
IIRC BMW did a supersession on the part # due to failures in or around 2007. They were known to weep or leak in early Z4M's and e46 M3's.
2006 Z4MC - #LL93158
      09-27-2012, 06:52 PM   #7
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Realoem shows the change in May 2007 in the attached link.
      09-27-2012, 07:25 PM   #8
DanFromTucson
Drives: Z4 M Coupe
How tough was this to change? Mine has the standard leak and I'm debating if I want to change it myself.
      09-28-2012, 10:29 AM   #9
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
make that 2 of us. Mine is leaky too and I wonder how hard is it? We need a DIY guide!
Found this http://www.m3forum.net/m3forum/showt...power+steering
The Raspinator
      09-28-2012, 12:13 PM   #10
DanFromTucson
Drives: Z4 M Coupe
Good find! That access doesn't look too tight, but hopefully the OP will share the difficulty rating for the M Coupe/Roadster.
      09-28-2012, 12:28 PM   #11
ZStig
instagram 997turbotom
286
Drives: Interlagos Z4MR
without a specially set up manual rack, just removing power steering from our cars would feel like crap
      09-28-2012, 12:54 PM   #12
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
Had mine replaced on the 2006 E85 and on the 2008 E86. Both under warranty, leaking. Common problem I was told on M's.
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      09-28-2012, 01:10 PM   #13
SCHMOUPE
SCHMOUPE's Avatar
ps the expansion hose by itself is 190 from Tischer. yikes
The Raspinator
      09-28-2012, 02:33 PM   #14
RichardTS
RichardTS's Avatar
Drives: 335i E92 & Z4 M
From the close up of the boss on the banjo, it looks like there are some hacksaw marks about half way around. Did it crack and then did you saw off the rest of it?
Is the bracket at the bottom of the 'U' attached to the body of the car? The broken part of the banjo is, presumably, attached to the pump?
I wonder if this is fatigue...
      09-28-2012, 08:55 PM   #15
elerner61
elerner61's Avatar
157
How are you guys noticing the leaks, spotting on the floor?
      09-29-2012, 08:24 AM   #16
22022
22022's Avatar
Thats a good DYI guide the power steering rack and hose are identical to our cars.
      09-29-2012, 08:33 AM   #17
22022
22022's Avatar
It was a Fairly easy job to do,on a stock car should take around 2 hr to do.On my car i had to remove some of the plumbing that went from the SC to the inter cooler and the banjo bolt #6 was a PIA!
      09-29-2012, 08:37 AM   #18
22022
22022's Avatar
I pay $235.00 up here in Vancouver,And they didn't even kiss me before they f*cked me.
      09-29-2012, 08:40 AM   #19
22022
22022's Avatar
It cracked,I broke the rest off removing it.
      09-29-2012, 10:27 AM   #20
SCHMOUPE
SCHMOUPE's Avatar
I guess that part 3 (expansion hose) is pretty much the culprit for all leaks and failures?!
The Raspinator
      09-29-2012, 10:29 AM   #21
SCHMOUPE
SCHMOUPE's Avatar
You need to get pretty intimate under the car to see the power steering rack and hose and notice the leak. I saw it when I was re-routing my O2 wires. Slow leak but a leak nontheless and I think will replace it next year when the car comes out of storage
The Raspinator
      09-29-2012, 11:10 AM   #22
DanFromTucson
Drives: Z4 M Coupe
You have to remove the whole plastic undertray to see it. I noticed my leak when replacing a broken undertray.
