06-02-2009, 02:34 PM | #1 |
Rep 335
where to get the rear center brake light
ok so for some reason the rear center brake light on my 2008 Z4 ROADSTER cracked. nothing around the light on the trunk is damaged, just somehow the light cracked. I thought BMW might cover under warranty but they wont and want $300 to replace it.
Anyone know where i can get one. The one i have is red but i have seen some people with a clear one, i dont care which one it is, new or used. thanks guys |
06-02-2009, 04:57 PM | #2 |
Rep 74
06-02-2009, 05:33 PM | #3 | |
Rep 1,660
For $300 were they trying to sell a full light assembly? That seems really high for just the lense.
Current: '13 E92 M3 Euro Delivery Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3 |
06-02-2009, 06:01 PM | #4 |
Rep 231
I just ordered one yesterday.
There is a red one and a clear one.. you choose. I have ordered many things from Tischer BMW. Check them out on www.getbmwparts.com The part numbers are 63256917378 RED 63256930246 CLEAR Take a look.. type in the part numbers.. the clear is slightly cheaper somewhere around $68 and the red is about $75. You may want to get the new springs and washers too since they were redesigned to prevent the cracking since it was caused by too much spring pressure. Good Luck.. It takes 10 minutes to swap out. Write if you need any assistance.
FS: Leather Recaro Pole Position Seats & Hardware |
06-02-2009, 07:10 PM | #5 | |
Rep 2,120
Also BMW will replace this light under warranty, Its a known issue with the roadsters and I have had one replaced, Best bet, Either go to another dealer or call BMW customer service and complain that your selected dealer wont replace something under warranty
Imola Red Roadster |
06-03-2009, 02:03 AM | #6 |
Rep 615
there is a service bulletin re: the center brake light cracking. Your dealer should replace it under warrenty since its an '08.
its on one of the forums... ill see if i can find it for you
'03 3.0i z4: tiag ext., red int., SMG, sport, premium
HAMANN exhaust l HAMANN front lip l 19" Miro type 366 (HAMANN edition race replicas) l RPI air scoop l KW v2 coilovers -*MY PICTURE THREAD*- |
06-03-2009, 03:23 AM | #8 |
Rep 615
