05-27-2009, 02:03 PM | #1 |
Rep 82
Question about cleaning the engine. What to use?
My engine looks dirty with sand and dust and other stuff. I've always been told it isn't a good idea to spray with water, but I've seen people doing it to their cars. Is it ok? Is there special cans of stuff to spray that is ok for the rubber and plastic pieces that will loosen up the grime? Thanks everyone.
05-27-2009, 03:39 PM | #2 |
Rep 602
Yes, it can be problematic if you go at it with a fury, or with high pressure or willy nilly. Caution works tho. I cover electrics [ie.alternator etcs] basically, [not anal about it] with mid size plastic grocery bag, and cover plug/coil towers with aluminum foil. Its easy, wraps to size and comes right off. Keep a roll in garage. I use and lightly spray Griot's Engine Cleaner [there are other prods], brush where needed with a long brush, tooth brush, and then rinse with a light sprinkling/rippling affect over it all. Frontal areas no problem as well. The motor is prepared to take some water, I just don't flood the thing, use a pressure washer here or at any local coin-ops etc. It comes out fine; I remove the covering, fire it up and let it run and dry out a bit. I start with a warm motor, and keep it clean so its not a flippin' mess to start with. Its fine and you will be fine with it. Just use a lot of common sense.
05-27-2009, 11:22 PM | #4 |
Rep 304
On my E46 M3, I just sprayed the bay down with simple green on a cool engine, let it sit for a few minutes, then hosed it off with a garden hose. Then go back and repeat with a bit of scrubbing for any stuburn areas.
zkeeper seemed to take a better/more professional approach so I would probably recommend that, but simple green and a hose did the trick for my 130k+ S54. Made all the aluminum shine and everything. By no means was this a engine detail....just a general cleaning. |
05-27-2009, 11:55 PM | #5 | |
Rep 82
simpe green
05-28-2009, 07:41 AM | #7 |
Rep 602
Vitamin T's simple green will work also...and no, I do not use a pressure spraying method...not at home or the commercial bays around. Nor a soapy spray of some sort. For me its too MUCH soap or pressure, and its simply not needed. The water comes from the hose with sprayer set on sprinkle..just rippling water to rinse things off. Gentle is the word. If motor is really grunged, then same method, but a bit more brushing, breaking down grunge. On fenders, up front, back, it may take a bit more rubbing, but it comes clean. One or more applications is fine if you have been a bit cautious on the covering of more sensitive electrical bits. But no pressure hosing to drive water and soap were I do not want. Hope that helps more. I love a clean engine compartment. You can lightly detail it, and there are lots of prods for this, but I don't use one that has an oily, or silicone base. Again for me Griots has been best.
05-28-2009, 10:19 AM | #8 |
Rep 326
I used the spray on cleaner/degreaser (can't remember the brand)
Just sprayed the aerosol can, waited 10-15 mins, rinsed off with a light hosing ...prayed while I waited for brief drying ...and re-started the engine
the stable:
2003 BMW Z4 3.0i 2020 Mitsubishi Outlander SE 2021 Jeep Gladiator Rubicon |
05-28-2009, 01:07 PM | #9 |
Rep 821
Use care with the simple green, it can be tough on some painted parts, bare metal parts, and stuff. Gunk used to make a good spray on, wait and hose off. I used to use the power washers on my show cars. Kept the enging compartment spotless.
05-28-2009, 01:14 PM | #10 |
Rep 29
Drives: 2006 Z4 3.0i Titanium/Black
WARNING! Simple Green
It has been found by the aircraft community that regular Simple Green can cause corrosion on Aluminum and some other metals. To answer this, they recently came out with a new product which will not cause corrosion to start.
Simple Green Extreme for Aircraft It may not be readily available at your local autoparts store. I think some of the Detailing web sites should start carrying it. There is a lot of aluminum under a BMW hood. |
05-28-2009, 02:06 PM | #11 |
Bad Lieutenant
232
Rep 3,517
Yes, and on the M, the entire hood.
05-30-2009, 04:08 AM | #13 |
Rep 140
Scrubbing Bubbles works too. Just spray it on, leave it for a few seconds and then spray it off with a hose. I haven't let the engine bay get too dirty, so no scrubbing is required.
05-30-2009, 07:16 AM | #14 |
Rep 20
06-10-2009, 01:15 AM | #15 |
Rep 144
cleaning the engine
did you cover any of the engine part with plastic before risinng it with water?
06-10-2009, 03:22 AM | #16 |
Rep 95
The emphasis is on light water use, not pressure. With pressure, sand etc would get lodged in threads etc where you do not want to have it.
I bought some AutoGlym cleaner spray and also protector which seems to be rated well by the guys on www.detailingworld.co.uk You can have a look there as well under the section "engine cleaning". |
06-10-2009, 09:52 AM | #17 |
Bates '08 Interlagos Launch
126
Rep 1,230
I saw a friend using wd40 to clean his interior engine bits and thought, omg what is he doing. Afterwards I was thinking that perhaps it wasnt too bad of an idea. It made everything nice and shiny and it obviously wont hurt electronics. I asked him if it would attract more dirt because of the lubrication properties, but I guess it evaporates off fairly quickly.
Thoughts? Anyone hear about this before? |
06-10-2009, 11:17 AM | #18 |
Rep 4,365
I just open the hood and use a shop towel to wipe it down after washing the car. No water except the damp cloth. Seems to work well as there is really no paint to scratch and I don't ever have to rub hard enough to scratch the plastics.
I am only really cleaning what I can see though, not going into crevices or on the sides of stuff at all.
