06-22-2022, 12:31 PM | #1 |
Rep 35
Top Opens But Will Not Close
As the title says, my electric top opens without any issues but will not close automatically. The motor does engage and you can hear the lines tighten up. I have to assist it until around the halfway point then it finishes closing on its own.
Any advice is welcomed! |
06-22-2022, 01:00 PM | #2 | |
Rep 2,706
06-22-2022, 10:21 PM | #4 |
Rep 158
Hey
Based on the facts you've given I've ruled out a slightly jammed emergency release bearing at the pump head since your pump/motor is new and relocated to the trunk. Your top works well when the top is going down since it has gravity working for it. However, when lifting the weight of the roof the pump/motor has issues. You might have a faulty pump...which could happen but is unlikely since it's basically new. However, in all likelihood your rubber seals within the hinge lifters are failing and simply allowing hydo fluid to past thru them when attempting to lift the weight of the top. |
kaybat125.50 |
06-24-2022, 05:55 PM | #5 |
Rep 355
Just went through this-Have you found any fluid by the rear wheels? If so, the hinges need to be rebuilt.
Mine was a head scratcher, as the drains were clogged, so the fluid just sat in the cavaties.
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
06-28-2022, 01:33 PM | #6 |
Rep 35
No fluid leaks found. Sorry, meant to mention that. This is a head scratcher as well.
