      09-02-2015, 01:07 PM   #1
Varinn
Drives: 2007 Z4MC
Z4MC alignment
Hey guys,
What are your thoughts on the alignment setup on my car for a mix of minor daily usage in the summer, street twisties, some lapping days, and some autocross? I'm currently finding that with the quite squared up back end that I have loads of grip in anything remotely straight but it's quite snappy through some turns.
I'm taking it to a buddy's shop and thinking to have him keep the front where it is (pins removed), but dial the rears in to at least within the oem range (around -1.9). I was never totally satisfied when the last alignment shop set the rear to -1.0 when I took it to them after replacing my RTAB's and installing limiters. They also insist on keeping the car for over one full work day so I don't really care to have them working on it again.
18x8.5 et35 with 245/40-18 Michelin PSS
18x10 et25 with 275/35-18 Michelin PSS
Front tire pressure was bumped to 36 for autocross and provided nice even wear and good scrub on the side without any obvious sidewall rolling. Rears do LOOK ok, and were run at around 32-33 psi cold for the last event, no obvious issues with it rolling onto the sidewalls or wearing inners/outers differently
1990 332i 5 speed (OBD2 S52 Swap)
2018 VW Golf R (6spd manual/copper orange metallic)
2008 KTM SuperDuke 990
2007 Z4M Coupe (#1026/1815) SOLD
      09-03-2015, 05:00 PM   #2
gmd2003
gmd2003's Avatar
352
Drives: 2014 CP M6 and 2006 VT 525 Z4M
Originally Posted by Varinn View Post
Hey guys,
You have too much tire/ wheel stagger for optimal handling , the way its set up it will still understeer quite a bit at the limit then oversteer on exit because of low rear camber settings. The front camber is about all you are going to get without camber plates , fine for mixed use but you will wear the outside edge a ton on track .Not enough rear camber for track or autocross or the street, it is significantly less than stock . For my mixed street track setup i run -3.2 front , -2.2 rear with 18x9 265/35/18 , 18x10 285/30/18's . Our ancient suspension geometry needs lots of camber.
George
      09-03-2015, 05:08 PM   #3
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I run similar settings to George's.
      09-03-2015, 05:27 PM   #4
Varinn
Drives: 2007 Z4MC
At my budget right now, I need to work with what I've got (so no major suspension changes or new tire/wheel purchases). The Z4 is still far and above a primarily street setup and usage, the e30 has always been my massively cambered track toy.
I think my front camber is maxed for what can be done with the stock setup and pins pulled.
I definitely want to keep the rear at least within stock ranges, maybe a bit more. I'm booked for an alignment tomorrow. Your description seems pretty accurate to what I experienced at autocross. I'll bring the camber to as high a number as I can get with oem adjustments all around and maybe run stock range toe front and rear.
      09-03-2015, 09:13 PM   #5
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Run zero toe upfront for better turn in.
      09-04-2015, 05:15 AM   #6
Beedub
whats everyones opinion on rear toe? where do we want this to be?
      09-04-2015, 04:53 PM   #7
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I'm running 1/8th total rear toe (1/16 each)
You don't need much but you need a little to help keep the rear from stepping out too eagerly.
