07-10-2013, 05:02 AM | #23 | |
Rep 11,667
Locktite is not recommended where it gets heated. Locktite will actually act like a lubricant under heat. There may be some hi temp variants available though. IMO this whole nordlock washer thing is overplayed. The issue from the factory is that they were not torqued properly. Just put them in with the regular washers,,,, torque properly and you will be fine. Go onto an E46 M3 forum and ask how many people have this problem. They won't know why you ask, because they don't have this issue. ....theirs got torqued properly at the factory. ,no locktite, no nordlocks .
07-10-2013, 05:22 AM | #24 | |
Rep 5,327
07-10-2013, 06:23 AM | #26 | |
Rep 11,667
I should add, that I did mine a while back with just the regular washers. I put a paint marker on the bolt head to monitor any movement. There has been none.
07-10-2013, 12:49 PM | #27 | |
Rep 1,663
The nord-locks are probably not required for the engine bolts. I still recommend them because I put them on my strut to firewall braces, and they're still perfectly tight after 1.5 years, while before I had to re-tighten them periodically. So I know they work as intended.
07-10-2013, 01:19 PM | #28 |
Rep 11,667
LOL... yeah, they had to come up with some excuse.
The randomness is what is strange. The Nordlocks are certainly a great product I looked briefly but had trouble finding one with a large enough seating area. IIRC some did find a match though.
07-10-2013, 03:08 PM | #29 |
Rep 1,663
I think I got the part number from bills web space, it's in my mod list though. Got them from McMaster-Carr.
07-12-2013, 01:37 AM | #30 |
Rep 2,860
Got these VT mounts (road version) installed today. These VT mounts are paired with my previously installed RE transmission mounts (no SSK). Initial impression is pretty much on par with everyone. Loving the more direct shifting action! It does live up to the hypes! However, there is definitely a slight increased in vibration, but only ever so slightly. It also raised my engine slightly as I can see the air tube being a tad bit closer to the strut brace. The minor raise in engine position could also be due to the worn OE mounts, although, the OE mounts appear to be in fairly good shape...but who knows
As a side note, I noticed that the rubber portion of the passenger side mount is slightly more compressed than the driver side after installation, but only by a tiny amount. Anyone else noticed this? Just being a nit pick. Overall, I'm extremely happy with this mod Thanks to all for providing the needed nudge in getting me to do this That's it...no more mods...at least for the rest of this year...famous last words Last edited by XMetal; 07-12-2013 at 02:29 AM.. |
07-12-2013, 05:26 AM | #31 | |
Rep 69
Yes, but E46 M3 was manufactured in Regensburg / Germany, while Z4M came from Spartanburg / US. However, the drivetrain was built in Germany. The question is: were the engine support bolts torqued by Hans or by John? |
07-12-2013, 06:18 AM | #32 |
Rep 11,667
Bubba
07-23-2013, 11:47 PM | #34 |
Rep 2,860
PM'd it to you.
07-24-2013, 07:23 AM | #36 | |
Rep 331
Can someone PM me the GB code?
07-24-2013, 06:13 PM | #38 |
Rep 1,031
07-24-2013, 07:53 PM | #39 |
Rep 400
07-25-2013, 01:54 AM | #40 |
Rep 1,543
Thanks Mirko. Got it and will be ordering soon..
By the way, anyone has those 10.9 motorsport bolts part number handy? How many will I need? TIA, Last edited by ZeD4Mr; 07-25-2013 at 02:27 AM.. |
07-25-2013, 09:10 AM | #41 |
Rep 97
07119913653 (6 pcs) M8x25 10.9
07119913673 (2 pcs) M8x35 10.9 07119903078 (8 pcs) washers ( by new ones or reuse) Oddly the long bolts are sold out at bmw europe?!?
perdidit in spatio
18" Arc-8 - Michelin Cup2 - KW V3 - GC camberplates - RE trans mounts - VT engine mounts - Vorshlag RTAB shims - RPi - stubby - CDV del |
07-25-2013, 10:16 AM | #42 |
Rep 165
Just to be clear since I wasn't able to find the part number on Realoem...are we talking about replacing items 3 and 10, plus washers?
bolts.pdf
'06 Z4 ///M Roadster: Silver Gray Metallic; Gray soft top. Zeckhausen CDV. ESS VT1 445 Supercharger. APEX ARC8's. Dunlap Direzza Star Spec's. Strong Struts. Royal Purple. RPI Exhaust w/ DKF hangers.
07-26-2013, 11:15 AM | #43 |
E86MPilot
23
Rep 265
You guys keep breaking my piggy bank.
Which version are most of you getting, Competition or Road? I'm concern it will transfer more engine noise to the cabin, my trans mounts are already loud enough.
E46M, E60/545I, E36/Z3M, E92M DTC, E93M 6spd, E86M(x2), F10 550XI (S2)(Current)
07-26-2013, 02:24 PM | #44 |
Rep 400
The vast majority of people are getting the road version. You can't go wrong with the road version, they will work with all setups.
If your FI and track a lot then you can get the Competition mounts. With those; however, you will get higher NVH at idle. Either way you go, you can buy the other compound insert for around $60 if your not satisfied. |
