      05-25-2016, 03:05 PM   #1
abelgonzaleZ4
Drives: 2006 BMW Z4 SilvrConvert 3.0i
Audio Aux cable doesn't work
Does anyone know why my Aux cable isn't being read by my radio unit?
I plugged it in to the far right corner where it says to plug in and it fits.
But my radio isn't giving me an AUX option on Mode.
Please help I'm tired of using an Fm transmitter to play my music
      05-25-2016, 03:07 PM   #2
abelgonzaleZ4
I want to ask around why it isn't working before I send it back. Please help if you know any tricks.
Very appreciated
      05-25-2016, 03:58 PM   #3
StickMon
StickMon's Avatar
Drives: 2006 MR
Do you have a link to the cable you added?
      05-25-2016, 04:31 PM   #4
bucko521
More of this than that!
bucko521's Avatar
Drives: BMW Z4 3.0i, Z3 2.5i
Some cables are wired wrong...and you need to 're-wire' into the current harness.
Check out this thread to read up on it.
http://www.z4-forum.com/forum/viewtopic.php?t=79054
and this one
http://www.bimmerfest.com/forums/sho...46&postcount=2
'06 Z4 3.0i Jet Black/ Biege/Black
Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill
Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector
      05-25-2016, 05:30 PM   #5
abelgonzaleZ4
Is anyone in LA that can help me?
      05-25-2016, 06:10 PM   #6
abelgonzaleZ4
I purchased a cable from eBay. It has a red, white, & yellow wire in a clip. I removed them and placed them in the OEM clip (bottom right under fuse) like the diagram shows next to the last two brown wires at the end top/bottom.
I put the white and yellow wires in top center and red on bottom 4th spot down. Under yellow.
Still nothing is working.
Frustrated in Pasadena ��
      05-25-2016, 06:15 PM   #7
abelgonzaleZ4
http://www.ebay.com/itm/321881985447...%3AMEBIDX%3AIT
The part I bought on eBay
      05-25-2016, 07:09 PM   #8
StickMon
StickMon's Avatar
Drives: 2006 MR
Looks and sounds a little suspicious.
At least you're only out $7.
I would recommend the stock cable.
The stock cable has a nodule in the middle of it with some mystery bits that may be needed for it to be recognized.
Here's an interesting thread.
      05-26-2016, 12:14 AM   #9
brother i
brother i's Avatar
14
Drives: '06 Alpine White Z4MR
Had the same issue, and read somewhere here on the forum that z4 needed a different cable that had a resistor in it. Ended up just getting an original part, which worked as expected out of the box. Thread linked by StickMon appears to suggest the same...
      05-26-2016, 10:55 AM   #10
abelgonzaleZ4
Thanks. Ya, I plan on getting my money back for a part that knowingly doesn't work from the seller.
I'll just have to save for the OEM part that costs $115.00 at a dealer.
Thanks everyone for you help!! Very appreciated
      05-26-2016, 05:51 PM   #11
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Why not go with the one that Stickmon linked to from ECS? It says it is OEM. It's only $33. Or this one from ECS that goes into the ashtray area. That's the one I have on mine. I bought a little 90 degree 3mm cable, and I can keep it all under the door when not in use. I have since installed an Intravee, but it was handy when I just connected an iPod.
https://www.ecstuning.com/Search/Sit..._174/ES194789/
Salty
      05-27-2016, 02:47 AM   #12
abelgonzaleZ4
https://www.ecstuning.com/Search/Sit..._Kit/ES194846/
This one Salty?
I have Bluetooth in my car. No Nav. I'm guessing I'll have to place this in the Bluetooth plug in the back (far bottom right)
      05-27-2016, 03:17 AM   #13
abelgonzaleZ4
I ended up buying this one on Amazon. It's from BMW/Mini of San Fransisco.
Part # 82 11 0 149 390
http://www.amazon.com/BMW-Genuine-Au...M+aux+cable+z4
Crossing my fingers it's going to work. Haha
      05-27-2016, 08:06 AM   #14
ShakyDog
ShakyDog's Avatar
Drives: 2007 Z4 3.0i Alpine White/Red
Have you tried using it with several devices. I know that most new Samsungs do not play through the AUX port due to some type of impedance. I would try with an older iPod or anything older with a 3.5mm output.
Steve
      05-28-2016, 04:06 AM   #15
brother i
brother i's Avatar
14
Hope the amazon cable works!!! It does say only that it fits 5-series, X5-s and X3-s... In any case, the one I got is https://www.ecstuning.com/ES194789/. Pricey, but definitely works, and still cheaper than from the dealer.
      05-28-2016, 06:20 PM   #16
abelgonzaleZ4
I hope it works too. Haha
It is a dealer part and same stock number as needed for my Car model. It is from BMW/MINI of San Fransisco
      06-02-2016, 01:24 AM   #17
abelgonzaleZ4
My ordered BMW OEM Aux Cable for $38.00 I ordered from Amazon WORKS!!!!!!! It really works!!!
Plug and play!!!!! I also have Bluetooth and I had to connect the two brown wires in the same plug into radio.
Everything works perfectly!!! Thanks Everyone!!
