      03-07-2016, 09:48 AM   #45
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Gauges are 52 mm that fit the 3D pod.
I'm partial to the Stack gauges myself.
Don't recall who I purchased from, but it was a Zpost vendor. (IND?)
I'm adding a 4th gauge for oil temp.
Just found this manifold on Bimmerworld that I'll be giving a try.
http://www.bimmerworld.com/Gauges-Da...ing-Block.html
      03-09-2016, 06:14 AM   #46
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
I just bought a set of gauges, going for oil Px, water temp and voltage.
any idea where to grab the ashtray cover? or is there a nicer way to do it? Not really that keen to spend 200 bucks on a moulded setup, worst case scenario ill make my own .
what did you guys do for the 3d pod?
Powered by
      03-09-2016, 06:32 AM   #47
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
The pod is a complex piece and well designed it replaces the complete top section .
Beedub's
There were other options from leatherZ that were a simpler design.
More of a flat plate that was screwed down.
The gauges sat much flatter
      03-09-2016, 09:43 AM   #48
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Ian, yeah looks awesome, but boy that pod is pricey, 350 us for just that pod piece is pretty darn pricey, any other sources that are still producing these?
Powered by
      03-09-2016, 11:36 AM   #49
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Price driven by demand I guess.
I considered fabbing something myself but caved in as I wanted to preserve the OE look.
Not aware of any sources for similar product.
LeatherZ stopped producing theirs as well.
      03-09-2016, 06:21 PM   #50
StickMon
StickMon's Avatar
Drives: 2006 MR
I like the looks of this, but the thing that always bothered me is they're in an inconvenient location to see.
Afraid I'd drive up somebody's backside while looking down at them.
Decided to just go with the iPod on the dash. I get water temp and volts, but would have to add a sender and A/D add-on box to get oil pressure.
      03-09-2016, 06:43 PM   #51
Steeler
Steeler's Avatar
2429
Not sure what an A/D add on box is but I added an oil temp gauge to my set up this year with a tapped oil filter lid.
Here is the S54 version https://store.vacmotorsports.com/vac...s54-p1065.aspx
This is mine, psi and temp
      03-09-2016, 07:22 PM   #52
StickMon
StickMon's Avatar
Drives: 2006 MR
The PLX KiWi OBD to WiFi has a plug on the back to string add-on Analog to Digital (A/D) converter boxes for numerous types of senders, like temp probes and pressure senders.
Gets expensive, though.
Not nearly as cool as good old analog gauges, but puts the volts and coolant temp right up on the dash where I can see them.
      03-09-2016, 07:44 PM   #53
Steeler
Steeler's Avatar
2429
Ah I see
Nothing wrong with hi tech
      03-09-2016, 10:12 PM   #54
StickMon
StickMon's Avatar
Drives: 2006 MR
Here it is in context. A little hokey, but a decent compromise for me.
      03-10-2016, 12:28 AM   #55
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
I LOVE VAN HALEN!!! 5150.. OU812…
right, back to the topic.. bought this
and then this for 6 bucks..
which ill mod to get about a 20-25 degree lean on the ashtray.. I hope. If it doesn't look any good, ill probably cave. anyways, its 6 bucks, can't hurt to see whats what. would have preferred a straight edge topside, but couldn't find one. who knows, this might be ok.
Stickmon, that looks bloody great mate, and pretty darn easy to let your eyes glance over to that and than back to the road.
Dbarton62, thats bloody great, thanks for the heads up. Might look at that myself, Ian also has a few pics that show other designated pickups, whack i may also look at.. all depending on the cost of said senders.
Powered by
      03-10-2016, 01:34 AM   #56
StickMon
StickMon's Avatar
Drives: 2006 MR
I considered the 6 buck pod for the dash, but the dash surface is at a very unfavorable angle. Especially if you have nav in the way.
I like the A-pillar option, although it may be a little JDM, but technically a good place for them.
But I have extended leather, so that means cutting cows.
Finally I said "screw it" I'll just use my Son's old iPod with the dead battery and DashCommand.
But the iPod versus analog gauges is like an SMG versus a 6MT.
      03-10-2016, 10:34 AM   #57
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Attachment 1379403
Is this the one you're currently using => http://www.plxdevices.com/Kiwi-OBD2-...7346002344.htm
Currently on sale too...good price!
      03-10-2016, 11:38 AM   #58
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Ian, sorry to bump this mate, but was looking for a few bits and pieces of info for when I attempt this.. Looking at running water temp, oil px and voltage or intake temp, not sure on the last one yet. Any recommendation for vdo suppliers? And what size are the gauges?
Water temp, intake temp, and voltage can be pulled from the P3Cars gauge. It also has three 0-5V programmable inputs.
If I had to go back and do it again, I would get a P3Cars vent gauge and radar-mirror.com gauges. It's more expensive, but it beats tearing up the interior to do the ash tray gauges.
      03-10-2016, 12:34 PM   #59
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I know what your saying, I have the tech side covered with a OBDLink MX Wi-Fi and my phone.
I can display & log just about anything, but nothing replaces the look of a good set of real gauges.
They should have been part of the OE design as the Z3 was.
      03-10-2016, 05:53 PM   #60
StickMon
StickMon's Avatar
Drives: 2006 MR
That's the one. Wow, that is a good price.
      03-10-2016, 09:28 PM   #61
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
What apps are you using it with?
Besides being able to add aftermarket readings, do you see any advantages of the kiwi over, let say, the much cheaper Veepeak Mini WiFi OBD2 scanner (http://www.amazon.com/Veepeak-Scanne...s=obdii+wifi)?
      03-10-2016, 09:59 PM   #62
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Stickmon's skin and parameters for DashCommand are slick. Really appreciate StickMon sharing it with the community. I use it with a cheap IOS WIFI OBD2 adapter that I picked up on Amazon.
http://amzn.com/B012MZGKOU
The above OBD2 adapter requires that the ignition be turned off and back on to make the OBD connection, but after that, it is reliable, though it does have a very slight lag. I don't know if that is due to the adapter or if the version of OBD2 protocol on the '06 Z4MR has a slow data transfer rate.
Salty
      03-10-2016, 11:18 PM   #63
StickMon
StickMon's Avatar
Drives: 2006 MR
I'm just using DashCommand, but there's a pantload of apps around that will work.
Here's my latest Z4 dashboard if you want to take it for a spin.
Here's some more creative ones from a user with more artistic talent.
I thin Salty answered your other question. Thanks Salty!
I set up with the KiWi years ago. There weren't many, if any, other WiFi adapters.
Cheap Bluetooth ones, but I learned BT doesn't work very well with IOS, even jailbroken.
The KiWi-2 has come way down in price, but the prices on the add-on modules are still insane.
I think the ultimate gauge setup would be an app on an iPad mini in place of the Navi screen.
      03-10-2016, 11:40 PM   #64
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
Thanks guys...really appreciates your feedback
      03-11-2016, 12:22 PM   #65
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
Attachment 1379479
Holy! R u in a airplane cabin?
Instagram: ariusen26
Youtube: Track vids
      03-11-2016, 12:29 PM   #66
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
nice DIY op!!!....these are mine....oil temp water temp and oil pressure....not sure its useful or just for show.... when i turn on the car its blue...when car is in normal temp its white and when its too hot its red....besides that I dont even notice its there lol...was even thinking of selling.
