06-11-2015, 09:11 AM | #1 |
Rep 566
Exhaust tips
Doing a stock muffler bypass with a butterfly valve but would like to replace the 2.5" stock exhausts.
Where would one find some 3" tips?
Add1cted
06-11-2015, 01:24 PM | #2 |
Rep 407
I got mind through eBay and cooped it with Magnaflow mufflers. Looked everywhere for the seller but couldn't find him. Instead I found someone else that has an identical tip. I found them through eBay but here's the companies direct website:
https://www.skspeed.com/ProductDetai...D=ETCDT-25083L (Left) https://www.skspeed.com/ProductDetai...D=ETCDT-25083R (Right) They also have one with a 3" inlet if you're planning on getting a large outlet muffler with it. |
06-29-2015, 12:17 PM | #3 |
Rep 407
I was also on the M5 forums and came across this:
http://www.m5board.com/vbulletin/par...pipe-tips.html It's pretty damn expensive but also pretty damn sexy. |
07-04-2015, 11:07 PM | #4 |
Rep 12,565
You should check these out. Stainless steel, double wall, 3" OD and I think 2.5" ID. A lot of E46 M3 owners switched over to these and had great results. Pricing is really reasonable too!
http://www.emnotek.com/p-256-stainle...aust-tips.aspx |
07-28-2015, 02:54 PM | #6 | |
Rep 321
07-28-2015, 11:29 PM | #7 |
Rep 12,565
I bought a set last year for my 135is. Was going to replace the factory tips off the PE but never got around to it. But I do recall the tips being really good quality.
On my Z, I have a pair of 3" dual slant cut tips on my custom exhaust. Picked them up on eBay but they really follow the lines of the bumper nicely: |
07-29-2015, 12:29 AM | #8 |
636
Rep 3,124
How the heck do they make those double wall tips?
My Diablos have them, and the taper on the I.D. is so clean it looks like they were machined from a solid billet of stainless.
07-29-2015, 07:55 AM | #9 | |
Rep 321
07-29-2015, 05:33 PM | #10 |
"The Midas Touch"
521
Rep 1,055
Drives: F87 LBB ///M2
I wonder if 3.5" tips will fit. The 3" Diablo tips seem a bit small its been something I've been wanting to swap out for a while now on my Diablo setup and also to single wall
07-29-2015, 06:16 PM | #11 | |
Rep 407
Here's 83mm tips on the Eisenmann exhuast: 83mm = 3.26772" 3.25" is probably ideal. Anything more it'll turn your bumper into s'mores. |
