View Poll Results: WPC treatment?
Yes 9 100.00%
No 0 0%
Voters: 9. You may not vote on this poll
      11-02-2015, 08:49 PM   #23
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Given your miles, that doesn't sound too bad! Still must feel nice to have it done.
Looking forward to some pics.
-Matt
      11-06-2015, 02:10 AM   #24
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Stick, glad your bearings were not too bad mate.. yeah i figured on 1000 kms and i generally drive below 4k , so no issues there mate.
I had my carrier bearing fail a few months back mate, and you'll know it when it goes man.. massive vibrations at launch, but smooths out when load drops.. (and not in every gear, pretty much only in 1rst and 2nd for me.)
i had my guibo replaced at the same time, though it was still in pretty ok nick..
Powered by
      11-06-2015, 11:22 AM   #25
Beedub
looking forward to pics.
      11-06-2015, 12:35 PM   #26
StickMon
StickMon's Avatar
Drives: 2006 MR
Pics
To recap - 128k miles, rarely over 5000 rpm, never over 7000 rpm, at least since I bought it with 40k miles.
Cylinder 1 --> 6 Tops on top, bottoms on bottom.
      11-06-2015, 02:08 PM   #27
tikamak
Lebanon
58
Attachment 1313683
Attachment 1313684
What Oil were you using?
      11-06-2015, 02:36 PM   #28
Drives: M2 Comp
Andrew did a test with rods off another S54 and the ARP bolts.
He found that if he stretched the ARP bolts to the prescribed 0.006" the bore was oval.
He had to stretch them 0.007" to get the bore round, and he wasn't comfortable over stretching them, so he went with stock bolts.
Thanks for the ARP info.
Props to Andrew for doing a test!
That's surprising info. It would be interesting to get some feedback from ARP.
      11-06-2015, 02:39 PM   #29
StickMon
StickMon's Avatar
Drives: 2006 MR
Castrol 10W-60. Standard ///M stuff.
Just switched to the new "Twin Power Turbo".
Something for those with ARP bolts to lose sleep over.
      11-06-2015, 08:46 PM   #30
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Stick, any close ups of the top 6 shells?
Those actually do look pretty knackered.
      11-06-2015, 09:19 PM   #31
Shipkiller
Shipkiller's Avatar
Drives: Me
Of course the uppers look bad.
The upper bearings have the most load, and wear first.
All in all, I think his bearing look normal for the amount of mileage he has on the car and the relative ease (no slam intended) in which he had driven the car.
It was just time for this maintenance and a rod bearing replacement will have to happen with every S54 at least one in its lifetime.
      11-06-2015, 11:11 PM   #32
NickyC
NickyC's Avatar
17465
I think those bearings look great considering the amount of miles on the car!
      11-06-2015, 11:34 PM   #33
StickMon
StickMon's Avatar
Drives: 2006 MR
Looks like #5 took a lot of time off work, and #6 has a limp.
Yours look more consistently worn, or maybe it's just because mine are only starting to get through the lead.
Name:  shells big tops.jpg
      11-07-2015, 01:19 AM   #34
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
thanks for the close up mate, yeah, mine were def much worse.. and your spot on for having this done mate, peace of mind is worth a lot.
I agree Ship, no hassle intended, just nice to get a close up of those top shells. i guess warming up the car properly is a massive factor on these engines and I agree, should be done on every S54 around 100k.
Whats next Stick?
Powered by
      11-07-2015, 10:40 PM   #35
StickMon
StickMon's Avatar
Drives: 2006 MR
BimmerWorld spherical RTABs.
Sway bar end links and bushings at both ends. Maybe stock, maybe not.
      02-26-2016, 11:03 PM   #36
StickMon
StickMon's Avatar
Drives: 2006 MR
And there you have it!
600% reduction in lead!
      02-26-2016, 11:34 PM   #37
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Wow...that looks fantastic - those WPC stuffs actually works
      02-27-2016, 08:11 AM   #38
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Congrats on that positive report.
Salty
      03-07-2016, 08:21 AM   #39
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
Just saw this thread and briefly read through it...
Originally Posted by tiltmode43 View Post
General question - Are there any proven cases of Z4M S54 failing due to rod bearings?
Mine did out of the blue two and a half years ago. Well maintained, occasionally tracked, semi-frequent use of 7000+ RPM, 65,000 miles... It scored 2 connecting rods and the crankshaft. Costed a lot of money to get it fixed here....
