      05-15-2016, 12:11 AM   #1
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
awesome alternator replacement video
so i'm planning on pulling my alternator tomorrow to replace the voltage regulator, and i found this great hd video showing how to get it out:
covers removal of other stuff in the area, belt routing, etc. wanted to share in case anyone else is working on the same thing.
      05-15-2016, 06:13 AM   #2
coh661
Drives: 2007 Z4M Coupe
2007 Z4 M COUPE  [8.00]
Great video. This will come handy someday for me I'm sure
      05-15-2016, 07:22 AM   #3
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Nice find! Thanks for sharing.
Salty
      05-15-2016, 09:14 PM   #4
jdoublehcubed
Mechanical Engineer
pulled and rebuilt my alternator this morning following this video, took about 2 hours at a relaxed pace. a couple differences from the video (which was made for an M54):
- no cooling duct at the bottom
- no need to disconnect the radiator hose
- no need to disconnect the oil hard lines
went much easier than i expected. the hardest part was getting the dust cover off the alternator to get access to the voltage regulator. there are jam nuts built in to the dust cover; to pull it off, you have to use a pick to round out the jam nuts. the voltage regulator includes replacement (regular) nuts in the box, so I think rounding out the jam nuts is what they expect you to do.
      05-16-2016, 12:18 AM   #5
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
Subscribed!thanks
Instagram: ariusen26
Youtube: Track vids
