      07-26-2011, 08:42 PM   #89
iPhoneEngineer
Drives: 2007 BMW Z4 M Coupe
Yeah, no doubt a few of the codes are related to the headers...
I'm quite curious about the brake booster code; perhaps the one-way valve for the brake booster was left out or improperly installed?
I haven't actually pulled codes using Rev, but don't have an SES light, so I assume that means none are set.
      07-27-2011, 10:12 AM   #90
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Getting no signal from my primary 02 sensors, which is probably causing the whole mess. The wiring from the engine to the headers was inspected, and the sensors themselves look new. ESS thinks they're not getting power to them, so thats the next thing we're gonna check tonight/tomorrow
(staying patient)
      07-27-2011, 05:12 PM   #91
Burn0utsRfun
Drives: Z3 M Rdstr
(staying patient)
Try checking out the throttle potentiometers.
      07-27-2011, 07:47 PM   #92
ZStig
279
Tonight, I've tracked down that I'm not getting any power to fuse #32, which is responsible for something in engine management. Hope to get more info Friday
      07-28-2011, 02:29 AM   #93
Beedub
awesome fault finding tom!!!
fuse 32 is this install related or something that can happen to any of us???
      07-28-2011, 09:17 AM   #94
ZStig
279
Thanks . I'm gonna have the tech look at it Friday, he's booked today. My only concern is that fuse 32 might be strictly for the SMG transmission, I hope I'm wrong and its responsible for the 02 sensors too
edit: yeah, fuse 32 is only for the SMG I'm told by a BMW tech
      07-28-2011, 01:06 PM   #95
ZStig
279
Did some dremel/plasti-dip work last night. I'm not sure I like the lower grill cut open like that. I may go back to stock
      07-28-2011, 01:22 PM   #96
Beedub
lol..... i like it!!! looks FAST even standing still
post a better pic please :-)
      07-28-2011, 01:38 PM   #97
ZStig
279
fine fine. btw, the lower grill is a complete bitch to remove from the bumper
      07-28-2011, 01:47 PM   #98
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
JMO, but I like it with the grill better.
I like the subtle but deadly look
      07-28-2011, 01:53 PM   #99
ZStig
279
yeah, I hope a new grill insn't too expensive. heh
      07-28-2011, 04:34 PM   #100
Beedub
i wont be modding mine as i want a sleeper look..... but i really like it!! looks uber aggressive.
byron
      07-29-2011, 05:16 PM   #101
Beedub
anything happening Re o2 sensor issues/tune issues??
      07-30-2011, 08:28 AM   #102
ZStig
279
One of my o2 sensors was completely gunked up from the car running rich for whatever reason. Ran great on initial startup. On second startup CEL came on, but thankfully for just P0030 code, which is 99% for the OTHER o2 sensors. Replacing that in a few hours today, hopefully that will do it, and not eat any more $$$ O2 sensors
      07-30-2011, 08:37 AM   #103
ZStig
279
byron
Yeah, sleeper look with world war 2 fighter exhaust? ooooook!
      07-30-2011, 07:18 PM   #104
ZStig
279
autoparts store delivered wrong parts, and then closed for the day....
      07-30-2011, 11:28 PM   #105
iPhoneEngineer
If you fouled your O2 sensor with just a single startup, mine must be completely annihilated at this point. Though I don't have any codes, perhaps it is contributing to the high-RPM power problem. Post some pictures of the old and new O2 if you can...how visually obvious was it that it was fouled?
      07-31-2011, 10:56 AM   #106
Beedub
did any of you guys log AFRs??
just for reference im seeing 3rd gear pull @ wot see's a nice safe rich 11.3-5ish, in the higher gears like 5th a WOT situation see's a 12.5ish richening out towards the redline, checking with AJ and hans this is the perfect situation and exactly what i should be seeing.
i wish i could mount my iphone somehow to grab some shots of my gauges during some runs...... Im going to try and grab a lady friend to do the camera work for me.....
also FYI tom and iphone, my "new" s/c unit has just had its first oil change @ 500 miles, i will do it again in anothr 500 miles, this oil change has rendered the unit almost silent, @ idle you can even hear it bar the whistle the s/c makes.
      08-01-2011, 08:51 PM   #107
ZStig
279
Made significant progress. The shop that installed my euro headers had put the secondary sensors in, and left the primaries out. OOPS!
Had to get 2 new primary o2 sensors, since the old ones went bad while hanging out in the air under the hood. I held off on welding in the rear 02s because I was initially told that its not necessary with the ecu tune.
Anyway, it only goes into limp mode at redline, except one time at 5k rpm. BUT not throwing any codes. So likely a tune issue, that I'll either find on the dyno on saturday or earlier if ESS sends the shop a portable unit
So at least I can ALMOST enjoy the car to the fullest... I'll try to grab some video tomorrow. Ordering a boost gauge too..
      08-01-2011, 10:18 PM   #108
Burn0utsRfun
Drives: Z3 M Rdstr
Glad to hear your close to getting it running well! Must be a lot of frustration, I would be going crazy ha.
      08-01-2011, 10:44 PM   #109
ZStig
279
I've been in much more stressful car situations, which taught me a lot of patience. At least the car was running more or less OK the whole time, I just couldn't drive it to its full potential.
but then again its not 100% yet, so lets see how patient I really am
      08-01-2011, 11:23 PM   #110
iPhoneEngineer
What do you mean...the wideband (primary) O2s were left plugged in but not installed in the exhaust? That seems pretty dicy, as I'm almost positive they have a heating circuit to bring them up to temperature. In any event, how could you tell they needed to be replaced?
I know what you mean about "more stressful" situations; I'm pretty damn worried about my kit, but it's not as bad as the time my Supra was behaving completely erratically due to a hidden, loose ECU ground .
