      03-30-2010, 01:25 PM   #1
DWG
Drives: 2006 Z4M
Reset windows on Z-4M
My passenger window goes up and then automatically down to about 3" above the sill and stops. I remember there is a way to reset the door closing window movement. Will that work to rreset this issue and if so how do I do it? Thanks, DWG
      03-30-2010, 05:41 PM   #2
imom
Drives: Subaru BRZ ....... Z4MR (SOLD)
common bug with the Z4. If I remember...just turn off the car and then turn back to on position and off again...I think that's what you do and then the window should reset.
      03-31-2010, 11:22 AM   #3
DWG
Drives: 2006 Z4M
Fixed
Let the car sit for a while and then reset window with key i position 1, didn't work when I first happen. All is well. Near as I can tell, except for a dead battery before I got it, this is first issue in 16K miles, about 3K since I got it. Fingers crossed. Thanks, DWG
