05-06-2013, 03:28 PM | #1 |
Rep 912
Z4M ESS VT2-500 supercharger kit Installation - Review - Driving - impressions
Hi everyone, I have a Z4M Roadster and I have supercharged it using ESS VT2-500 beta kit.
I will start by sharing the dyno and reserve the next thread for everything else in terms of build, pointers, impressions, etc. The car is making 457 rwhp and 340 wtq. I have the following mods that affect power: * Euro headers * Euro S-pipe with emptied cats with the catalysor chamber left to pseudo-resonate * Stock resonated X-pipe * Rogue Engineering El diablo mufflers * Vanos timing mechanically advanced by 3 degrees Never mind the next runs as it was 30 degrees Celcius heat and the dyno fan was not hitting the intercooler or oil cooler. This is after 100 Kms of adaptation and break-in. Also never mind the AFR as my gauge is showing 11.6 AFR instead of 10.6 and this is the accurate reading. Last edited by tikamak; 05-07-2013 at 01:44 AM.. Reason: Adding photos |
05-06-2013, 04:01 PM | #6 |
Rep 5,327
Mega power!!!! This 500 is kicking ass.....
Mechanically advanced the vanos timing??? Is that a good idea??
05-07-2013, 01:47 AM | #10 |
Rep 912
It's not that much advanced timing because the EML will light up if it was. it's only 3 degrees and the vanos will phase it out and will only be useful on full throttle when the engine is advancing timing to the max.
when the timing is being retarded to the max, e.g. low RPM, very low throttle input, the car will feel a little wierd, smooth but wierd, like it's not able to decide if it should go or stop, when you step on it, the tyres light up. The fuel used is 98 RON imported from europe and is the most shittiest fuel you can see. |
05-07-2013, 05:08 AM | #11 |
Rep 5,327
this is 550 type numbers.......
good to see the 500 with catless can do the numbers!! the Tq is insane!! not to sure on messing with the vanos however......
05-07-2013, 05:17 AM | #12 |
Rep 912
05-07-2013, 06:59 AM | #13 | |
Rep 441
Very impressive...just curious why you didn't hold off for the 525 kit?
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread |
05-07-2013, 08:39 AM | #14 |
Rep 912
I didn't know it existed and when i asked AJ about it, he said the 525 kit is different in fuel injectors and tune and he needs more money to do it.
05-07-2013, 09:50 AM | #15 |
Rep 441
I see, I figured you had purchased it more recently (when they would've disclosed the 525 development) seeing how you've had it installed for 100km so far...regardless you put out solid numbers...higher than eas dynoed their 525 kit
My Build Thread |
05-07-2013, 10:05 AM | #16 |
Rep 912
Yes i'm very happy with the car, it's throwing out blue flame on engine cut-off like an AK47.
I will explain everything when I have some time to write a proper review. |
05-07-2013, 02:47 PM | #17 |
First Class M
20
Rep 217
Drives: Z4M Coupe, E36 Coupe
awesome numbers you have got there bro. happy for you man
'07 Z4MC l Alpine White l Supersprint Race Exhaust l Supersprint X Pipe l OEM Carbon fiber Spoiler l H&R Springs l Vossen VF051 l G-Power SK I 415 rwhp l RPI Scoop l ///M Performance Knop. |
07-21-2013, 03:03 PM | #18 |
Wagon life
39
Rep 991
Hey tikamak!
I'm curious as to the tune you were provided by ESS... did it inclue the provision for catless headers? I want to put headers on my car, but was told that it's made for use with stock headers. Kit is a VT2-500 as well. Thanks! |
07-22-2013, 01:20 AM | #19 |
Rep 912
The tune I was given by ESS works with catless headers as well as catless everything. I don't have cats in my system, at all.
07-22-2013, 10:05 AM | #20 |
Wagon life
39
Rep 991
