07-23-2013, 08:53 PM | #23 | |
Rep 400
Running the engine very much might not be wise with those sounds. |
07-23-2013, 10:48 PM | #24 | |
Rep 86
07-24-2013, 04:48 AM | #25 |
Rep 400
You don't need the entire shim kit, especially if your car isn't going anywhere for a while. All you need is a micrometer, offset thickness gauges, and the shim tool. Measure the shims, figure out what you need and order that from BMW. Maybe get a couple of extras. There are tons of shims you probably will never need in the kit. If you do some searching you can find the range that most people require and get those ahead of time. That's what I did. I had to order additional shims, cost some time without car , but saved some money also. Here is a thread I started about my valve adjustment.
07-24-2013, 04:44 PM | #26 |
M = Midlife Crisis
65
Rep 2,006
How would any of this have been damaged in an accident? Did you check to see if the passenger side motor mount had broken loose and dropped the engine? Makes one helluva a noise running afterward with the exhaust supporting the motor. Likely not the culprit but worth checking.
2006 Z4MC - #LL93158
07-25-2013, 07:59 PM | #28 |
636
Rep 3,124
Definite possibility of a Vanos problem, from what I've heard of it compared to the noise my broken Vanos bolts made.
If it were me, I would immediately pull the head cover and see what's up. It's not as hard as it looks. I've done it without replacing gaskets and grommets, with relatively new gaskets and grommets installed. The worst it can do is dribble a little oil after you get it back together.
07-26-2013, 01:49 PM | #29 |
Rep 86
So since it's a Friday, got off work early and started to tear apart the head cover and guess what I found? 5 shim fell off, the vano tabs looks to be good and still in place. I'm hoping the fix would be to replace put the shim back on and do some valve adjustment.
07-26-2013, 02:17 PM | #30 |
Rep 400
Good find. Glad we have those oil drain guards.
Make sure all your spring clips fit tight to keep the cam followers in place. You can go ahead and measure clearances and order the correct shims to save some money on a kit. |
07-26-2013, 06:12 PM | #33 | |
Rep 932
Glad you find the problem. |
08-01-2013, 09:38 PM | #35 |
Rep 86
adjusted valves today and it did not solve the loud ticking, it did become alittle tad quieter. Thinking about running the CEL codes and maybe do a compression test just incase. Almost positive I can hear it ticking from the header side or close to it. Frustrating!
