03-22-2010, 01:06 AM | #1 |
Rep 661
correct transmission fluid on the m?
Has no one done transmission fluid change on the m? I can't find any info!
http://www.zpost.com/forums/search.p...rchid=11486592 I want to see which transmission and lsd fluids people use on the M. I heard that on the new bmw's, they put in ATF for manual transmission?
Future mod consideration: exhaust, pulley
otherwise, very happy with how the m3 was born |
03-22-2010, 02:12 AM | #2 | |
Rep 666
I take my one gallon plastic jug down to BMW Seattle and the parts guys fill it up with SAF-XJ differential fluid and charge me $8.14 per 500ml under P/N 83 22 1 467 993. http://www.bimmerfest.com/forums/sho...83&postcount=1 For the transmission: http://www.bimmerfest.com/forums/sho...85&postcount=3
Jim Millet
03-22-2010, 07:47 AM | #3 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
I changed mine to Royal Purple Synchromax High Performance Manual Tranny Fluid and I'm enjoying easier shifting. Supposed to keep it cooler and less friction also. Some people claim it's too thin but as I change mine very 20,000 Im not to worried about it. I know I've seen quite a few "M" guys running it for the tranny. I"m staying with the stock fluid for the diff when I change it. Here's a good "DIY" about 3/4 way down page... A great link with some good Mods... Thanks Bill
http://billswebspace.com/bmwmc.htm Just be careful of stripping the fill nut. Id use a stubby hex from snap on if you can find one or you could have this happen and have to buy some Vise Grips...LOL http://www.zpost.com/forums/showthread.php?t=356204
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings Last edited by mousitch; 03-22-2010 at 02:00 PM.. |
03-22-2010, 01:48 PM | #4 | |
Rep 661
sorry if I didn't specify that clearly. but it's a good idea getting fluid like that
03-22-2010, 01:49 PM | #5 | |
Rep 661
thanks!!
03-22-2010, 02:59 PM | #6 | |
Rep 666
Are you using something other than Castrol TWS Motorsport SAE 10W-60 Synthetic Engine Oil? http://www.bmwusa.com/Standard/Conte...ngineOils.aspx
Jim Millet
03-22-2010, 06:43 PM | #8 | |
Rep 661
but just that i've been a fan of redline and RP for tranny and lsd fluids over stock.. that's all and assumed there are more members like me
03-22-2010, 07:08 PM | #9 |
Rep 666
When my warranty expires in September 2011 I may consider putting a 50/50 mixture of Red Line MTL and MT90 in my Z4M transmission and Red Line 80W-140 gear oil in the differential. Until then I'll stick with the BMW recommended fluids.
Jim Millet
03-23-2010, 07:51 PM | #10 |
Custom User Title
149
Rep 661
07-20-2011, 04:54 PM | #12 |
Rep 844
I've been running the Royal Purple Synchromax in the tranny for close to 6k now. It does feel thinner. I'm considering changing it over to Redline MTL. Maybe mixing with MT-90, not sure yet. Running Redline 75w140 in the diff for 6k also and it's been perfect.
07-20-2011, 09:13 PM | #13 |
Rep 376
BG syncorshift 2, I've used it in many tranmissions with excellent results. Shifts much better than OEM, I'll post analysis from Blackstone soon.
09-13-2011, 11:13 AM | #14 |
Rep 855
Im using Pennzoil Synchromesh right now and I like it. May try RP or Redline this time idk
2014 335i M Sport
2010 328i M Sport 2007 Z4MC #1019/1815 (Sold) 1997 M3 (Sold) 1991 325i |
09-13-2011, 06:10 PM | #16 |
M = Midlife Crisis
65
Rep 2,006
RP - Yes...
2006 Z4MC - #LL93158
09-13-2011, 06:50 PM | #17 |
Rep 855
yeah definitely its a lot smoother than stock. If you havent done it already look into the CDV delete also it makes a big difference. Im gonna be doing the clutch stop this week
2014 335i M Sport
09-15-2011, 07:24 PM | #19 |
M = Midlife Crisis
65
Rep 2,006
The Transmission was not designed for this car's drive train or power... It sucks period. I purchased an extended warranty because I fully expect it to fail at one point.
09-19-2011, 01:06 PM | #20 |
Rep 855
You know the ZF transmission is stronger than the transmission in the M3 right?
2014 335i M Sport
09-19-2011, 02:20 PM | #21 |
M = Midlife Crisis
65
Rep 2,006
The Getrag 420G transmission in the e46 M3 and others was designed to handle the torque load placed on it by the S54 and similar motors. The ZF Type H in our cars apparently was not. Fact is it was added to Z4M cars because the Getrag would not fit. I have never seen the torque spec on BMW part # GS6-37BZ (ZF Type H), however, many have speculated its not up to the job or Getrag e46 M3 unit.
09-19-2011, 05:35 PM | #22 |
Rep 855
i will check the torque spec but my friend who is a BMW fanatic said the ZF is capable of handling about 1000 horsepower just like the Getrag does on the HPF M3's. If youve ever driven both they pretty much feel the same. Notchy in first and second gear and a slight whine due to the design of the gears
2014 335i M Sport
