06-15-2021, 02:50 PM | #1 |
Rep 21
`06 E85 3.0i ... what to look for?
Newb question.
I'm about to look at a 2006 3.0i automatic w/ 45K. I've owned a `02 E46 325i auto for 15+ years, so I already know about their problem areas. I've also read here about the `vert top drainage issues. Anything else I should look at? Wife & I are treating ourselves to something fun. We love the Z4 styling. TY for any other suggestions. |
06-15-2021, 03:17 PM | #2 | |
Rep 4,058
Any water in the trunk? Lift the floor and check the battery spot etc. Good luck and post pics ! |
06-15-2021, 04:31 PM | #3 |
Rep 4,058
Also check that the rear defogger works, that the back glass is undamag and the canvas is in good shape. The top and glass are one part so a broken glass means a new top.
06-15-2021, 04:48 PM | #4 |
Rep 1,343
Generally this generation of Z4s are fairly simple. N52 is solid. Looks like this is a detuned version with 215hp as opposed to the 260hp si version. Typical N52 maintenance includes VCG, OHFG, Vanos Solenoid etc. Apart from VCG, the others are easy DIY.
I think the biggest worry is the convertible top motor that can malfunction. If you see water residue in the rear compartment then chances are the motor was subjected to the water. I think the most expensive part is the canvas top. Make sure it's well cared for. |
06-15-2021, 05:08 PM | #5 |
Retired
96
Rep 174
I would have a good look underneath for missing or damaged panels. Check the steering for play during your test drive. Missing plastic bits under hood or in wheel wells.
06-15-2021, 06:57 PM | #6 |
Rep 21
Thanks everyone for the suggestions. Owner says that the top previously malfunctioned, but was replaced under warranty. Most of the car's maintenance supposedly was done by my local BMW dealer, with documentation.
We'll see. |
