02-26-2013, 08:43 PM | #1 |
Rep 446
Drives: 2013 335is
Z4 M - RPMS Went Crazy
Driving home Saturday the car started acting nuts at shut down and start up. Bouncing rpm=500-700 and then not staying running. Service Engine Light came on.
Indy shop says vvt error and other's but they conflict with each other, did my vanos go out?
2013 335is E93 2018 X5 35d BMWCCA / ZSCCA Member |
02-27-2013, 08:19 AM | #3 |
Rep 446
Drives: 2013 335is
Shop thinks it the IAC.
I'll see if he will tell me the codes.
03-02-2013, 01:35 PM | #4 |
Rep 446
Drives: 2013 335is
It was not the IAC after he replaced it.
03-02-2013, 02:26 PM | #5 |
Rep 1,772
Drives: 2007 Z4M Coupe
were you able to hook it up to a bmw code reader?
03-02-2013, 02:46 PM | #6 |
Rep 446
Drives: 2013 335is
Yea, I hooked it up to the one I have, but I did not down load the codes. Car is at Indy shop right now.
03-04-2013, 06:05 PM | #7 |
Rep 446
Drives: 2013 335is
It was the bearing on the intake hub. I don't know how you can check it to prevent that from happening. It never made a sound, even when the mechanic got in in the shop and was testing. He found the one piece that broke that sealed it in. But the whole unit has to be replaced. So fellow M owners, keep a eye out.
03-04-2013, 07:31 PM | #8 |
Rep 820
Drives: 2007 Z4MR silver grey
Sorry to hear this. How many miles are on your car now?
John |
03-04-2013, 07:45 PM | #9 |
Rep 446
Drives: 2013 335is
Only 45k.
03-04-2013, 08:52 PM | #10 |
Rep 820
03-04-2013, 09:14 PM | #11 |
Rep 446
Drives: 2013 335is
My baby is a garage queen. You are not safe just because you don't track your car. It does not make a difference.
03-04-2013, 10:25 PM | #12 |
Rep 820
03-13-2013, 05:29 PM | #13 |
Rep 446
Drives: 2013 335is
https://www.facebook.com/media/set/?...2794429&type=1
I posted on Facebook in the ZSCCA all the pictures of my Vanos. The car is back together and I can tell at least a 30 percent drop in the noise. Maybe because it's I have not been it in a while, in either case it runs like a top now. I can certainly tell the difference in the performance. And yes, it was an arm and two legs this time. $3800.00 clams to get it fixed.
