      04-12-2014, 10:40 PM   #1
RADRACR
RADRACR's Avatar
Window auto-up doesn't work.
Got car back from shop.
Auto-down works.
Auto-adjust when door opens/closes works.
Auto-up doesn't work.
Searched and tried a few home remedies to no avail.
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts
'09 X5 35dSpace Grey / Saddle Brown
20" Forgestar F14 / SCR Delete
      04-12-2014, 10:48 PM   #2
VinnieAces
VinnieAces's Avatar
Drives: Imola Red Z4MC
2006 Z4 M Coupe  [8.00]
ah its something along the lines of having the car key in the accessory position (before igniting the engine) and then holding up on the window button for 10 seconds. I remember programming mine not too long ago after swapping batteries
///M - Some Mods 'N Stuff
      04-12-2014, 10:56 PM   #3
Small Yellow
Track Addict
Small Yellow's Avatar
Taiwan
110
Drives: 2010 BMW M3 E92 | 2008 Z4M E86
Auto-down works.
What i noticed is if you reset the window positions by putting it in the position before starting and push the window down button and hold it for 5-10sec then hold them up 5-10 sec it will reset windows. Sometimes after resetting it still wont work normally but after waiting a day it works again randomly. I dont know why but it does. Windows get this issue when battery is pulled
BMW ///M3 Coupe
Completed November 16, 2009
Received December 29,2009
      04-13-2014, 09:29 AM   #4
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
It will randomly start working again. Happened to me many times after services.
      04-13-2014, 12:44 PM   #5
StickMon
StickMon's Avatar
Drives: 2006 MR
The Official Reset Procedure
      04-14-2014, 01:09 PM   #6
RADRACR
RADRACR's Avatar
Originally Posted by StickMon View Post
I saw this. English is my first language, but I don't understand. It reads like a poor translation of German. I've taken a stab at it but no good. Can anybody verify if this does work, and explain the procedure better?
      04-14-2014, 01:35 PM   #7
StickMon
StickMon's Avatar
Drives: 2006 MR
Yea, reads like Google Translate.
1) Open the window and push the open button 4 more times
2) Close the window, but don't let go of the switch when it gets to the top for at least 2 seconds
3) Open it again, but let go of the button when it gets to the bottom
4) Close the window, but don't let go of the switch when it gets to the top for at least 2 seconds
IIRC, after the window gets to the top and you're holding the button for 2 seconds, a relay clicks. Then you know it's done.
      04-14-2014, 01:52 PM   #8
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Same with me. It happens when battery is disconnected. Will come back shortly most likely
      04-14-2014, 01:53 PM   #9
Gle8
Drives: 2007 Z4Mc
What works for me:
1) With window closed, open it and continue to hold button for 10 seconds.
2) With window open, close it and continue to hold button for 10 seconds.
Should be good after that.
