01-15-2011, 02:28 PM | #1 |
Rep 91
valve adjustment
Hello,
I have heared about valve adjustment on a M just recently. Never heared about it before. When has it to be done? And what are the costs? Thanks for the info. Regrads Yves |
01-15-2011, 02:36 PM | #2 |
Rep 4,726
every 10k-15k miles ish should be sufficient. Around $500
01-15-2011, 03:18 PM | #4 |
M = Midlife Crisis
65
Rep 2,006
It's more like 22-30K miles
2006 Z4MC - #LL93158
01-15-2011, 03:39 PM | #5 |
Rep 176
Drives: 2006 Z4 3.0si Coupe
Should this be done on the 3.0si as well?
01-15-2011, 03:41 PM | #6 |
M = Midlife Crisis
65
Rep 2,006
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM Last edited by Caddyshk; 01-15-2011 at 03:56 PM.. |
01-15-2011, 03:57 PM | #7 | |
Rep 176
01-15-2011, 04:02 PM | #9 |
M = Midlife Crisis
65
Rep 2,006
Way different...
01-15-2011, 06:35 PM | #10 |
Rep 2,782
3.0si has hydraulic lifters, just like 99% of the other cars on the road. There's no need for a valve adjustment. Valve adjustments are more of a "have to" than a "get to" with the M.
OP: There's a DIY out there to show you what's involved, but I wouldn't attempt it myself if I didn't know what I was doing. Do a search. Valve adjustments are supposed to be done every inspection (22-30k miles). |
01-15-2011, 07:42 PM | #12 |
M = Midlife Crisis
65
Rep 2,006
BS - I drive it like I stole it on the street, and do 4-6 HPDE's per year. Mine is winding 24,000 miles for Inspection 1 - Sorry Ocha... No early work for you...
01-15-2011, 08:01 PM | #13 |
707
01-15-2011, 08:07 PM | #14 | |
Rep 4,726
YMMV
01-15-2011, 08:13 PM | #15 |
707
01-16-2011, 02:27 AM | #16 |
Rep 4
Valves adjusted on my 2006 M Coupe with 20K at dealership. All valves required shims to bring into factory spec however, tech stated that the wear was within expected for mileage.
01-16-2011, 03:26 AM | #18 |
Rep 4
I did notice a slight decrease in motor noise but no performance difference before and after adjustment. The necessary adjustment was within the range of normal engine wear.
