      12-18-2010, 05:56 PM   #1
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
SS X-pipe and SS pipe adaptor project update
Just got my x-pipe adaptors in and unfotrunatly they are the same diameter as the x-pipe itself. This will prevent adaptors from slipping in the pipe. But I believe I can pull the stock pipe off and get a good measurement then have the adaptor welded on to the end of the x pipe with the spinning collar flange in between for a perfect fit. What is nice is that the adaptor already has a "bell" type end which will mate up with the stock or eisenmann exhaust perfectly with the donut gasket. Will update as this will not happen till late March at the soonest.
Pics of the adaptors,ss adaptor and spinnong collar flange......Sorry bout the nasty greasy wall/light switch. Its my experimental grage lab. LOL
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      12-20-2010, 02:29 AM   #2
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Are you sure the adapters won't slide in? Mine took some convincing via rubber mallet, but they went in smoothly; albeit I put the adapters into the receiving end of the muffler cannister, not your specific case
      12-20-2010, 06:31 AM   #3
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
This what I was expecting might be the case. (from the other thread)
Another option to consider.
Some muffler shops have the equipment to flare a pipe to make a slip over joint.
You could flare the X pipe. (the adapter is probably to small to do).
But I would probably go the welding route as well.
      12-20-2010, 08:40 PM   #4
mousitch
Dark Sider
mousitch's Avatar
129
Tried to fit it every way. Like putting a circle in a square hole. I believe the SS cans have a smaller diameter tubing so they will slide over or vice versa. The adaptor and xpipe are dead on in diameter. The way I look at it, if welded it will give someone the option of using it on OEM oe any other can beside SS's if I ever sell down the road. May actually increase the value of the part.
      12-21-2010, 02:01 PM   #5
mfanatic325
///M-fanatic
Taiwan
193
damn SS and their choice of flange design...
      12-21-2010, 02:18 PM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^+1
With a little more thought they could have made the X-pipe universal fit.
I guess their thinking is; they want to push you to buy their cans instead of some other brand.
It's too bad someone doesn't make am OE X-pipe replacement.
      12-21-2010, 04:49 PM   #7
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
Here http://www.**********s.com/Rogue-Eng...4-M-X-Pipe.htm
      12-21-2010, 04:52 PM   #8
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
^ Would have been perfect for Moustich's old car, with the RE Diablos. =)
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
      12-21-2010, 05:01 PM   #9
mousitch
Dark Sider
mousitch's Avatar
129
damn. I bet it will fit the coupe just fine. Ive already sunk $700+ with the adaptors. Crap. Good find though. Maybe I can sell the pipe and adaptors. The OEM part numbers are the same for the coupe and roadster. Any one $550 for pipe and adaptors-Shipped? LOL
      12-21-2010, 05:22 PM   #10
Diokaef
Engineer
Diokaef's Avatar
You just need to expand the adaptor to fit over the x-pipe and after that use a Clamp to hold together should cost you about $100 to do it.
      12-21-2010, 05:31 PM   #11
mfanatic325
///M-fanatic
Taiwan
193
Sell me your X-Pipe for $450 shipped. I'll make good use of it XD !
I just installed headers, and would like to unlock some more potential power before I do dyno runs ^_^
      12-21-2010, 07:47 PM   #12
F360C
Drives: E86 S54
Hmmm these went inside the pipes on the supersprint cans but the SS cans have a slit cut on either side of the pipe. I guess that allows the pipe on the exhaust cans to expand just enough for the adapter or the xpipe to fit inside the cans. I am wondering if you could just cut the same two slits the xpipe to allow just enough play for the adapter to fit in. I will try and get a picture of what I mean. I think it might just be a matter of you getting the dremel tool out to get these to fit.
07 Z4 M Coupe AW/IR
      12-21-2010, 08:47 PM   #13
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by Diokaef View Post
WOW... thanks!!!
How long has this been out?
I had no idea that there was one available.
...new item on the list
      12-21-2010, 09:33 PM   #14
Diokaef
Engineer
Diokaef's Avatar
They being available for a few months, but I knew they would come out before, I have to know my competition and their quality.
      12-22-2010, 09:16 AM   #15
mousitch
Dark Sider
mousitch's Avatar
129
Just an update: RE x-pipe not availiable till late January, February. But Im gonna wait it out. Just sold x-pipe.
      12-22-2010, 10:03 AM   #16
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^thanks, I got the same info.
They are obviously waiting for a container to arrive.
From past experience, if they're expecting Jan-Feb; that will likely mean about March.
Since mine is in storage anyway, that works out fine.
-ordered.
      12-22-2010, 10:49 AM   #17
Diokaef
Engineer
Diokaef's Avatar
^ very interesting, not the same info that I have tho.
      12-22-2010, 10:52 AM   #18
Diokaef
Engineer
Diokaef's Avatar
But they are in the market right? just not available at the moment correct? or they just sold a few for testing purpose?
      12-22-2010, 10:55 AM   #19
RBull
Drives: 2007 M Coupe
Sorry I wasn't the one.
      12-22-2010, 11:02 AM   #20
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
They are on back order, waiting for a shipment to arrive. (container from China)
      12-22-2010, 11:03 AM   #21
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Did you find some SS cans?
      12-22-2010, 11:04 AM   #22
Diokaef
Engineer
Diokaef's Avatar
Got it!, Thank's for the clarification
