      06-08-2016, 04:52 PM   #23
IndyHo
Drives: 2007 Z4 3.0si
Definitely a must. Great that you found this and thanks for the post...
      06-08-2016, 10:49 PM   #24
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Yeah, since BMW is discontinuing the assist program for older cars using the older communication technology like ours, there isn't any reason to keep the old switches in place, so I went ahead and did this mod. Nice little pocket for a phone, wallet, etc.
Salty
      11-07-2016, 02:18 PM   #25
thrak410
Drives: 2004 Z4 Roadster
I put mine in, but it doesnt seem to fit right. I think the bottom of the tray is hitting the airbag module under there... could mine be in backwards? Its even lifting up the trim.
      11-24-2016, 11:47 PM   #26
Bimmer_Addict
Drives: 2006 Z4M Roadster
No way you can install it backwards. Make sure the wire bundle and connector are shoved out of the way, it looks like they are pressing upwards.
      12-05-2016, 12:46 PM   #27
rsutoratosu
Drives: Z4 3.0i
https://www.turnermotorsport.com/p-1...uine-bmw-part/ beige for those of us that doesn't have black..
-Roranji
      08-24-2018, 03:55 PM   #28
fgottlieb
Drives: 2007 BMW Z4 3.0si
I would actually like to use the wiring for powering an iPhone charger. Does anyone know which wires do what?
      11-09-2018, 09:53 AM   #29
KevinC
your average JAMF
KevinC's Avatar
Thanks for reviving this old thread, I just ordered one from FCP Euro. Absolutely no point in keeping the switches since not only did BMW discontinue the service, but I'm pretty sure it used an analog Verizon connection and that network no longer exists.
As for the earlier problem with losing Bluetooth communication - did anyone else have any problem with this?
'21 M2 Comp
'19 Golf R
      11-30-2018, 12:45 AM   #30
KevinC
your average JAMF
KevinC's Avatar
Installed. No loss of Bluetooth. Oddly mine was already disconnected when I popped the switch panel. Great to have a bit more storage space when there's so little to begin with.
'21 M2 Comp
'19 Golf R
