      06-06-2014, 01:25 PM   #1
MinneapolisJeff
Drives: 2003 BMW Z4 3.0i
tranmission leak?
Just got my car back from its annual oil change, the dealership noticed and noted that they "found oil at the rear of the transmission". Very vague. Service rep had nothing else to tell me. Also mentioned that the only way they'd find the source of the issue is to do the diagnostic test which involves cleaning off and using a dye to determine source of the oil.
So, is this a fishing expedition by the stealership? Or have any other 2003/2004 E85 owners out there had a similar issue? I'm inclined to clean it myself and wait and see. No oil marks underneath the car in my garage. It had been stored in the same spot from Nov until last month (so 6 months)
the stable:
2003 BMW Z4 3.0i
2020 Mitsubishi Outlander SE
2021 Jeep Gladiator Rubicon
      06-06-2014, 01:47 PM   #2
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
Did you narrow it down to engine or transmission oil?
      06-06-2014, 01:55 PM   #3
MinneapolisJeff
that's the thing, they couldn't even tell me that... very odd commentary on the inspection sheet they fill out that comes with the oil change
the stable:
2003 BMW Z4 3.0i
      06-06-2014, 02:13 PM   #4
RobMCoupe
RobMCoupe's Avatar
60
Check if leaking from top rear of transmission. Maybe selector shaft seal. Number 8 on realoem.
http://www.realoem.com/bmw/showparts...53&hg=23&fg=15
      06-06-2014, 02:34 PM   #5
MinneapolisJeff
is that pretty easy to get a look at if I had the car up on ramps?
the stable:
2003 BMW Z4 3.0i
      06-06-2014, 06:20 PM   #6
RobMCoupe
RobMCoupe's Avatar
60
It is difficult as the flex disc is blocking the view. You can check if there are fresh oil with a rag or paper towel.
If it is the seal, replacing it is a PITA.
