      05-25-2014, 09:45 PM   #1
tel
tel's Avatar
Drives: 2008 3.0si Roadster Slate grey
Wheel Spacers
Thinking of adding spacers to my roadster. What size looks the best on the rears ?, Is 15mm enough ? Is 20mm to much. I have run flat tires.
Thanks for your opinions.
      05-25-2014, 11:18 PM   #2
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
20 will give you wobble most times. 15 looks pretty nice, go with the turner ones, plus the stud conversion.
stud conversion is worth its weight in gold, every time you take the wheels off you'll wonder why you didn't do it sooner.
      05-26-2014, 07:15 AM   #3
tel
tel's Avatar
OK 15mm on the rear it is then. I might as well do the front. What do you suggest for the front, smaller I would think, 10mm or less ?
      05-26-2014, 11:08 AM   #4
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
You also need either extended lugs or a stud conversion.
      05-26-2014, 04:27 PM   #5
unluky
unluky's Avatar
7528
I just did the rears and went with 15mm. You can see the pictures here.
http://www.zpost.com/forums/showthread.php?t=987793
I think 20mm would still tuck in there just fine though. I tried them up front and I did not like the 15mm up front at all, too much tire eased for me from the front.
I went with the turners and they fit great.
      05-26-2014, 05:01 PM   #6
M-Power M3
Retrograde
M-Power M3's Avatar
18
Drives: Bagged Z4
I run 25mm on my stocks and I'm fine with OEM sized tires, even when I air all the way down. I have 15mm up front with OEM sized tires and that cuts it close when I'm most of the way down.
Oh and no wobble here and I drive 350+ miles a week on them.
Bagged e85 Z4 | www.ogretrograde.com
Bagged TT 225Q SOLD - e46 M3 SOLD - W202 SOLD - e46 325i SOLD
      05-26-2014, 05:06 PM   #7
tel
tel's Avatar
What did you end up putting the front ?
      05-26-2014, 07:45 PM   #8
3798j
3798j's Avatar
11426
Drives: E86 3.0si
'55 Ford F100  [0.00]
'08 Z4 3.0SI  [8.50]
'66 Triumph TR4A  [0.00]
'85 Corvette  [0.00]
'64 Corvette  [0.00]
'68 Triumph GT6  [0.00]
'19 VW Golf "R ...  [0.00]
On mine it's 15mm fronts, 20mm rears purchased on ebay (hub centric and included longer wheel bolts - sorry don't remember price). No interference, no problems.
      05-26-2014, 07:54 PM   #9
GuidoK
GuidoK's Avatar
10866
Drives: Z4 3.0i ESS TS2+
20mm on the rear is no problem (tested to 174mph, no stability problems). No rubbing either. (stock 255 R18 rear tyres)
15mm on the front can give some rubbing (stock tyres/rims) on the inner plastic wheel housing with (eibach) lowered springs and cornering really hard and sharp.
Especially the lowering is the cause in that.
      05-27-2014, 03:40 PM   #10
unluky
unluky's Avatar
7528
3798J's 15mm fronts look much better than mine did, but we have different wheels as well. Mine were just slightly sticking out of the wheel well. Just a shade past flush.
His look great.
      05-27-2014, 05:15 PM   #11
unluky
unluky's Avatar
7528
I left my front with no spacer at all. I may try a 10mm up front, but left them with no spacers and put the 15mm in the back. The rear certainly can stand 20mm I believe as I still have a little room left with the 15mm for sure.
The pics on my old post in the "after" side are 15mm rear and no spacers in the front.
This is 15mm rear and no spacers in the front as well where as my sig (harder to see I know) is stock.
      05-27-2014, 06:21 PM   #12
M-Power M3
Retrograde
M-Power M3's Avatar
18
Drives: Bagged Z4
Not the best shot to see but 15mm up front and 25mm in the rear with 225/45/17
      05-27-2014, 07:10 PM   #13
tel
tel's Avatar
They look good..
      05-27-2014, 07:24 PM   #14
mtownerman
Drives: 2006 Z4 3.0i
Stock suspension? Fenders rolled? Any rubbing along the inside or outside of the tire?
      05-27-2014, 10:09 PM   #15
M-Power M3
Retrograde
M-Power M3's Avatar
18
Drives: Bagged Z4
Bagged, fenders are slightly rolled. Minimal rubbing in the front, over large bumps it'll rub on the liner. At a more conservative "sport drop" height I have zero issues. Rear has tons of room. Pictured is about 3/4 the way down.
