      05-11-2022, 11:18 AM   #1
gutus
Drives: 2006 535i
Z4M Oil Drain Plug
Hello,
Does anyone know if there is a magnetic drain plug for the Z4M engine oil. I'm only finding results for magnetic plugs for the differential.
Also, when using the stock plug, do you replace it with each oil change? A 6mm hex seems like it would be prone to stripping.
Thanks
      05-11-2022, 02:26 PM   #2
wdb
dances with roads
wdb's Avatar
4732
I don't know of a magnetic drain plug but I have also not looked. I just replace the copper gasket when I change oil, not the plug itself. If you're stripping it you're using far too much torque; everything is aluminum including the threads themselves. Go easy.
      05-11-2022, 03:31 PM   #3
grannyknot
grannyknot's Avatar
952
Drives: 2008 Z4M coupe
What he says ^
Even though the filter comes with a new copper washer I generally don't replace it and it seals just fine, no leaks.
2008 E86 M coupe
      05-11-2022, 05:50 PM   #4
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
It is important to follow the torque spec for many items on the Z4M.
It is my understanding the following is the torque spec for:
Oil Pan Plug: 18 ft lbs
Oil Filter Bolt: 24 ft lbs
Overtightening is the most common mistake that causes failure(s).
Strongly suggest using a torque wrench to ensure torque values are upheld.
Racerbruce
      05-11-2022, 08:42 PM   #5
gutus
Drives: 2006 535i
Thanks for the info! I haven’t changed the oil yet. I was just thinking ahead, so this is good info for me.
racerbruce3853.50
wdb4732.00
      05-12-2022, 11:15 AM   #6
Reborn_
Drives: 2007 BMW Z4MC
I also suggest getting a hex driver set. Makes it way easier and less likely to strip the hex portion (not the thread).
racerbruce3853.50
      06-05-2022, 08:06 PM   #7
kaybat
kaybat's Avatar
Drives: '06 Z4MR, '14 Cayman S
'06 Z4M  [0.00]
https://drvanos.com/collections/s54-...tic-drain-plug
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
      06-07-2022, 11:40 PM   #8
gutus
Drives: 2006 535i
Wow…are you using one of these? It looks different from z4 bolts so I’m curious about compatibility. I’ll send the an email.
      06-09-2022, 12:46 PM   #9
tomjonesBT33
tomjonesBT33's Avatar
Drives: 2006 Z4 M Roadster
Folks - prompted by this threaded, I ordered and received one of the DrVanos magnetic plugs. I haven't installed it yet but thought I'd give you my initial impressions. First shipping was very fast. Order it on Monday, received it on Wed. Shipped from TX to Mid Atlantic (VA). Packaged well. Quality looks very good. Comes with a new aluminum crush washer.
Magnet is quite strong given the size. Probably Neodymium. I used a suitcase scale to measure its strength. The magnet can support 2.2lbs (1kg). So plenty strong to capture metal shavings in the oil.
I'll be installing at my next oil change and will report more then and after the subsequent oil change.
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic
2012 X5 M - Monte Carlo Blue Metallic
2017 X1 xDrive28i - Alpine White
kaybat125.50
wdb4732.00
      06-09-2022, 04:18 PM   #10
gutus
Drives: 2006 535i
Thanks for sharing. Looking forward to your install opinion.
      06-09-2022, 07:08 PM   #11
wdb
dances with roads
wdb's Avatar
4732
I want to know who took that picture with both your hands in it.
bosstones1154.00
      07-30-2022, 10:37 PM   #12
gutus
Drives: 2006 535i
Just wanted to confirm that this bolt does fit. Here is the one I https://www.turnermotorsport.com/p-581409-magnetic-oil-drain-plug-dimple/
      07-31-2022, 09:57 AM   #13
grannyknot
grannyknot's Avatar
952
There is also this one from Mishimoto, a little more surface area and less expensive.
https://www.garagistic.com/collectio...-e24-e31-z3-z4
2008 E86 M coupe
