01-15-2012, 05:43 PM | #23 |
Rep 12,570
Huh? Thats the opposite of my post. Z-rated not good in cold, Akrbobo ceramics good in cold.
01-17-2012, 03:59 PM | #25 |
549
Rep 5,695
We've ran Cool Carbon brake pads on several of our cars and they have less dust than OEM pads. They also have a much more linear bite and feels much easier to modulate under heavy braking!
01-25-2012, 08:30 PM | #26 |
Rep 313
02-05-2012, 02:28 PM | #27 |
Rep 1,816
Drives: E86 3.0si
I too had had it with the brake dusting - short drive on clean wheels and they needed cleaning again. Went the Centric PosiQuiet Ceramic route and couldn't be more pleased. They fit my driving style and tastes - I'm in the old car hobby and a number of my other rides require that firmer first pedal application, and while there are no track days, there are what I'd describe as "spirited" driving moments.
Purchased from one of my favorite parts supplier: http://rockauto.com/ and the pads arrived the next day. The happy ending - minimal dusting that doesn't cling. |
02-06-2012, 04:04 PM | #29 | |
Rep 4,002
Cool Carbon pads are usually very low noise; make sure to remove the previous friction material or other coatings from the rotor surface with BrakeKleen and green Scotchbrite pad before installing new pads; also good idea to apply noise free to back of pad backing plate; CC pads can generate a bit more dust until fully bedded which can possibly cause some noise; this can be eliminated by flushing the caliper with water from a hose, but only do this when rotors are cold. http://www.coolcarbonperformance.com/faq.html
Robert T. | european auto source (eas)
email: robert@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x21 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
02-06-2012, 08:49 PM | #30 | |
Rep 91
Thanks for the tips Robert. I love my CC pads
02-16-2012, 05:35 AM | #31 |
Get Some
226
Rep 759
Drives: 07 Z4 3.0si
I bought the stoptech performance slotted rotor setup, bedded them as they recommended, and have absolutely no squeaks, stops on a dime, and extremely minimal dust, just the usual road grime. The complete kit was less then $700 for 4 rotors, pads, and steel brake lines and a great product imo
03-02-2012, 05:41 PM | #32 |
Rep 45
just put a set of Akebono pads and a new set of brembo discs on two weeks ago. brakes are great and after two there is little to no brake dust!!! Haven't had any brake noise either and i would expect the braking power to get better after a thousand miles or so. I am totally sold on Akebono pads.
Last edited by damikmak; 03-02-2012 at 05:43 PM.. Reason: forgot to add something |
03-04-2012, 09:35 PM | #33 |
Member
Rep 30
Drives: 2006 Z4 3.0si Roadster
I have experience with Akebono and Hawk ceramic pads on my E46. Rotors were different, but I think the Hawks had better initial bite. That's what I'll go with on the Z4 when I do the brakes next month.
03-05-2012, 10:20 AM | #34 |
Rep 206
I have the Hawks ceramic. They are great. Minimal dust, and bite better than stock. My only problem with them is that I had to modify them for them to fit. They had a couple tits on the back of the pad that the stock do not have. I ground them down and they fit no proplem and I have had no issues with them. I called and cross referenced to make sure I had the correct pads and was told I did.
03-06-2012, 09:36 AM | #35 | |
Rep 313
Great info in the thread, hopefully I can wait out winter since my sensors haven't been tripped. |
03-06-2012, 09:43 AM | #36 |
Rep 206
Even when it was below -30 there was no noise. Only time there is some noise is when you hammer on the brakes. I also did not notice much difference at that temp compared to stock.
03-08-2012, 11:16 AM | #37 |
Rep 21,753
Cool Carbon Pads provide excellent performance year round with very little dust or noise; also very rotor friendly, linear and easy to modulate. We have many repeat customers on these pads and run them on our own cars.
Don't miss out on our 30/30 sale during March. http://www.zpost.com/forums/showthread.php?t=658317 https://www.europeanautosource.com/specials http://www.europeanautosource.com/ma...bonPerformance
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
08-07-2012, 08:09 PM | #38 |
Rep 313
Update: so I bought centric premium disks and akebono pads
Here are my old disks and pads, suffice to say they were ready to be changed Now, my rotors are working as expected but the akebono brakes are terrible, I haven't done a brake fluid change but the pedal feel is terribly spongy. Initial bite is very weak. What kind of bedding procedure did you akebono buyers use? Also I washed the car (surface rust appeared) and I realized there is a gap between the hub and where the pad meets the disk. Not a large gap but I don't recall this on the oem brakes. |
08-07-2012, 08:19 PM | #39 |
Rep 11,668
How long has it been since the brake fluid was last changed?
08-07-2012, 10:19 PM | #41 |
Rep 12,570
09-01-2012, 01:54 PM | #42 |
Rep 114
Another resource is parts geek. I thought about going with all high dollar replacements but ended up staying pretty much stock once I realized I'd never use the car for anything more than spirited back road driving. Besides, I share a common story as many other Americans.......I'm making two thirds of what I was 5 years ago but the bills/expenses have gone up. I bought centric rotors, stop tech pads, all new hardware and new wear sensors for $388....... DELIVERED. I couldn't be happier because it stops quicker than stock and I saved almost $700 over buying stock from BMW. The dust problem is almost non existent and what little there is rinses off easily with no scrubbing. http://www.partsgeek.com/catalog/2007/bmw/z4/brake/brake_rotor.html
04-22-2013, 10:10 PM | #43 |
Rep 1,530
Great thread! I earned a lot. I bought my car with 15K and currently have 22k on it. I believe the brakes were recently done just prior to the car being sold to me. How much more life can I expect out of the brakes before I can swap them out with something better? I really can't stand all the dust.
