      01-27-2018, 03:36 AM   #1
lrz
Drives: BMW Z4M
Z4M error codes, help needed
HI guys,
What is the problem according to this ecu errors?
      01-27-2018, 08:10 PM   #2
mattfwalters
mattfwalters's Avatar
Drives: 06 Z4MC (Sepang/Sepang/insane)
Can't be certain, but my guess would be that "sensor stuck rich" code is the more causal one. If the computer is trying to trim out a nonexistent rich condition caused by a bad sensor, the (still good) post-cat sensors screaming about an actual lean condition make sense.
Both post-cat sensors reading a lean condition is bad, regardless. Don't drive the car like this.
StickMon636.00
      01-28-2018, 07:00 AM   #3
lrz
Drives: BMW Z4M
I have no mufflers so I guess the post errors are not relevant or harming the engine.
      01-28-2018, 01:28 PM   #4
Boosted 1
Where Does He Get Those Wonderful Toys?
Boosted 1's Avatar
Drives: 07 M coupe, Gx470, M2 PE
I got 2 of your 3 codes after I put on my section 1 pipes. Since they are post I wasn’t to concerned. I did eventually replace the post o2 sensor and reset the codes, they haven’t returned.
      01-28-2018, 08:36 PM   #5
mattfwalters
That's quite an assumption. Feel free to make it, of course, but if the ECU is actually trimming fuel based on the "stuck rich" input due to a bad sensor, your car might actually be running lean on that bank.
      01-30-2018, 07:08 AM   #6
lrz
Drives: BMW Z4M
I have SS stepped headers, I read here in the forum that this is the cause for the problem.
How can I fix it? Which sensors do I need to relocate and where?
      02-01-2018, 05:56 PM   #7
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
After I installed SS stepped headers I did not get these codes.
Do you have a tuner in your area? If it were me, I would have it diagnosed. Maybe a custom tune will rid you of the problem.
