10-27-2010, 06:38 AM | #50 | |
Rep 11,668
In that case I'll probably go back to the stock knob. ...I'll see if there's a way to add a little weight to it.
10-27-2010, 11:22 AM | #52 |
///M-fanatic
193
Rep 3,885
Ronald says he needs specs for those of you that need threaded tops for your special shift knobs. Please PM me if you need those, so that I can let him know ASAP!
Also, he may hafta charge up to $20 more to ship kits outside of the USA. RHD model will not be an issue. You're covered. |
10-27-2010, 11:46 AM | #53 |
Rep 633
JB Weld can be a way to add weight as well if there is a void where the stuff can be poured in. I (some what shamefully admit) have an '89 Camaro that I put a different shifter in and it had a smaller diameter threaded end on it than stock. So, I just filled up the hole in the knob with JB Weld, drilled it and tapped it for the correct thread size and it worked out great, and added a bit of weight too. It may or may not work for our application, dunno because I've never had the stock knob off to see what it looks like.
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=| Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo) RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint |
10-27-2010, 12:53 PM | #54 |
Rep 11,668
No problem; I assume that will be sorted via email from Ronald?
10-27-2010, 01:33 PM | #55 |
///M-fanatic
193
Rep 3,885
Yes, I'm assuming that he will go through the list of everyone's contact info and proceed to collect funds thereafter.
But I'm pretty sure he won't start requesting funds until AFTER the kits have finished production and are ready to be shipped out. |
10-27-2010, 02:42 PM | #56 |
Rep 11,668
FYI.. Autosolutions has a lot of interesting info on their website
10-27-2010, 03:00 PM | #57 |
///M-fanatic
193
Rep 3,885
Yeah they're pretty well known company with lots of experience, so I trust them wholeheartedly.
10-27-2010, 03:49 PM | #58 |
///M-fanatic
193
Rep 3,885
This was Ronald's response in regards to the threaded top request:
That's not a problem but I cannot guarantee against breakage at or above the threaded area. the standard shaft is approx 15mm in diameter. For a shift knob to safely work you would need the threads to be used strictly for retaining the knob and not to be subject to shear. I.e you would need the knob to apply force to the 15mm shaft and not to the threads. Thus the knob in question must be checked for dimensions that would allow the force to be applied to the 15mm shaft. please remember that the outer lever is 6061 t6 aluminium and not steel. Hope that explains my position in this regard. I told him that you guys wanted 10x1.25 thread pitch, at 1 inch length down from the top tip of the lever. Diokef and Dorifto, please let me know ASAP if you guys still want to proceed with the threaded request. All these need to be sorted out before Ronald can go ahead into production. |
10-27-2010, 07:08 PM | #60 | |
///M-fanatic
193
Rep 3,885
There was absolutely no play in the shifter when I test-drove. It was actually so solid that it felt tight. I know we all like that tight feel >_^ As for the threaded tops, we've all decided to not take any risks and just go with OEM-style shift knobs instead Last edited by mfanatic325; 10-30-2010 at 01:05 AM.. |
11-06-2010, 01:23 AM | #64 |
///M-fanatic
193
Rep 3,885
So unfortunately we're slightly behind schedule. Ronald informed me of production plans this upcoming week instead of this past week
I'm kind of antsy to get this kit in my car as I'm planning on tracking the car more and more. Please bear with me guys! I want this to be finished and ready just as much as anyone, if not moreso |
11-06-2010, 03:21 AM | #66 |
///M-fanatic
193
Rep 3,885
