      05-05-2024, 05:01 PM   #1
Jays.-.beemah
Jays.-.beemah's Avatar
Drives: 2003 bmw z4
2003 bmw z4  [0.00]
Repaint faded z4 m steering wheel
Hey do you guys know what paint I should use to paint the e85M steering wheel from fade?
      05-06-2024, 03:35 PM   #2
Z4Kevo
Z4Kevo's Avatar
85
Drives: 2007 M Coupe
As my plastic coating was scratching off I disassembled the trim parts...used rubbing alcohol to remove the remaining coating (down to bare plastic)...and then sprayed them with SEM Products 15243 Satin Black Color Coat. Looks great! Almost, but not quite OEM look.
2007 BMW Z4M Coupe | Sapphire Black | 19" ZCP Wheels | Michelin PSS - 245/285 | Carbon Leather
Black Corners | UUC Short Shifter | ///M Racing Pedals | OE Strut Brace | LED Accents | PEMP Android
      05-07-2024, 06:28 AM   #3
mmm-five
mmm-five's Avatar
Drives: 2006 Z4MC + 2015 320D M-Sport
Is this the steering wheel leather cover or the plastic trims you're asking about?
      05-07-2024, 09:24 AM   #4
spielnicht
Petrolhead
spielnicht's Avatar
445
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
If you want professional results, do the following:
  • Trim Plastic Pieces: Reach out to fellow forum member Texaz3. He has a great process for repainting them for a 100% match of the original color and sheen, but much more durable. He repainted a bunch of pieces for me and I couldn't be happier.
  • Leather Wrap: Check out either https://cobywheel.com or https://www.redlinegoods.com. Coby redid my F10 steering wheel and it came out awesome.
2024 X3 M40i
2014 550i
2008 Z4 3.0si 6MT
2011 Z4 35si (sold)
      05-08-2024, 11:59 PM   #5
Jays.-.beemah
Drives: 2003 bmw z4
2003 bmw z4  [0.00]
Fixed it and it came out really nice with almost the same oem feel. Attached are before and after
      05-09-2024, 09:45 AM   #6
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Looks great - How did you end up refinishing it?
      05-09-2024, 10:23 AM   #7
Jays.-.beemah
Drives: 2003 bmw z4
2003 bmw z4  [0.00]
Thanks it was kinda easy, all I did was pull all the trim off and sand them, then I went to autozone and bought a special plasti dip (https://www.autozone.com/paint-and-b...&gclsrc=aw.ds) make sure you allow the plasti dip to warm up by putting it in hot water and when you spray make sure it’s thick or else you’ll get bad orange peel (when you spray it thick it will look glossy but also smooth that’s how you know you are spraying right). That’s pretty much it sanding was the most annoying part lol. But I liked how it came out also don’t fret if you get orange peel just peel it off and start again!!
XMetal1167.00
