      05-31-2014, 07:49 AM   #1
addictedto1
Drives: 2009 BMW 135i
Finally! OFFICIAL Turbo Z4 M COUPE DAILY BUILD THREAD!
Hey guys!
Im new here, I know, but I have been lurking for a while. I am rebuilding a wrecked 07 M coupe with more than just body panels, however.
I will be updating this thread over the next couple of weeks with pictures, as the car is repaired and turbo kit is fitted.
I will be working with several companies, whom I wont mention until the end of the build and its success.
But, after all these years, someone found a good solution on being able to tune these "turbo" cars, and I will be the first person/future distributor for them.
Anyways,
so the start.
2007 M coupe
28,XXX Miles
Bone stock.
The heart?
ARP headstuds
MLS Gasket ( still deciding on thickness, oem or bigger)
Radium Universal Catch Can Kit with Petcock drain kit and custom aluminum mount.
Mounts against passenger side firewall.
http://www.radiumauto.com/Universal-...-Kit-P178.aspx
CutoutController
QTP cutout wireless controller box.
http://www.quicktimeperformance.com/Wireless/
EngineMount
Custom fabricated remote engine mount and remote isolator mount.
Moves engine isolator mount forward 7" to make space for turbo.
Exhaust
Custom fabricated full turbo exhaust with QTP exhaust cutout,
Eisenmann Race exhaust.
http://www.eisenmann-sportauspuff.de...3_2l_252kW.php
FexSensor
Siemens Flex fuel sensor with -6AN quick disconnects and mount.
Mounts behind driver side headlight.
FPR
Aeromotive fuel pressure regulator and custom fabricated mount.
Mounts to the inatke manifold and base of the block near bellhousing.
http://aeromotiveinc.com/products-pa...ass-regulator/
FuelFilters
Black inline -6AN fuel filters with fuel lines to regulator and rail.
Mounts to middle of the base of the block.
FuelRail
Custom billet fuel rail with -6 ends and top feed.
Interooler
Front mount intercooler kit for Z4M with Tial Q BOV's.
Requires front bumper beam removal.
MidPipe
Custom fabricated stainless 3 inch exhaust midpipe with flex tube and QTP electric cutout.
Oilcooler
Setrab oilcooler with stainless lines and -10AN fittings and custom mounting brackets.
Mounts to the top of intercooler.
50-625-7612 Setrab series 6, 25-row oil cooler, 22mm ports 263.00
OilLines
Left to right. Turbo coolant line, Oil feed line, Valve cover oil drain.
Surge
Custom fabricated surge tank with dual Bosch 044 fuel pumps and relays.
SurgeTankLines
Stainless -6 fuel lines from fuel sender to surge tanks and to engine bay.
Routes over differential and length cut for truck mounted surge tank.
Turbo
Garrett GTX35R with twin scroll 1.05ar and custom cover for Z4M routing.
https://www.turbobygarrett.com/turbo...arger#GTX3582R
TurboManifold
Custom fabricated tubular twin scroll manifold and dual Tial MV-S wastegates.
http://www.tialsport.com/index.php/t...egates/62-mvsx
TurboOilDrain
Stainless turbo oil drain to oil pan with -10AN fittings.
VacuumBlock
Billet aluminum vacuum block with ProEFI 5 Bar map sensor and turbosmart
electric boost controller.
VacuumRail
Modified OEM vacuum rail with -6 fitting welded to back.
HPF polished intake manifold w/o HPF Logo.
Clutch is a South Bend Stage 3.
Pump gas 600WHP GOAL. DAILY DRIVEN, practically STOCK block besides the hardware/gaskets.
Future plans for E85, perhaps low compression pistons/rods as well, and eventually push the car to 750-800WHP
Let the games BEGIN!
      05-31-2014, 07:53 AM   #2
addictedto1
By first person I mean, based in the United States. There are currently 3 turbo M coupe Z4s, one of which is making nearly 1000WHP on a built motor.
They exist, they work, and they will now be accessible by the general market after my trial!
      05-31-2014, 10:45 AM   #3
CMH_328XI
Drives: bmw z4 mr
buy my z for a spare parts car man
      05-31-2014, 03:29 PM   #4
2skiddy
Drives: Z4M Coupe
Ooooh this will be interesting and will give me a bit more hope that I'll finish my Turbo Z project over here in the UK one day!
      05-31-2014, 03:41 PM   #5
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
A few things to note here: you're not the first in the US, the "working" ones don't really work as they should, and I'll check back in two to three years when you finish the tuning... Trevor's car (which seems to be the inspiration of your build) has been through three or four standalone ECUs and two and half years of tuning, so I don't think your car will be much different. Good luck though.
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      05-31-2014, 09:35 PM   #6
Nate4641
Nate4641's Avatar
Drives: '07 M Roadster
Good luck, be sure to post a ton of pics!
      06-01-2014, 08:15 PM   #7
addictedto1
Actually, there have been 2 attempts in the USA for these. HPF failed, and the last one which was done by lab 22 worked but the owner decided to go to flex fuel, and they faced new issues they couldnt resolve and parted the car out.
Who is trevor? I know of basar who has a stand alone/e46m3 ecu and the cluster doesnt function along with many other options.
      06-01-2014, 08:51 PM   #8
Bayonet
Drives: Z4 Mc
G'luck I hope you could do it..... a turbo would be badass
I believe this is the trevor ratedM speaks of ...I was following for a bit back in the day but haven't heard much since http://forum.e46fanatics.com/showthread.php?t=889263
      06-02-2014, 09:26 AM   #9
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Actually there have been working turbo cars, though far from daily drivers.
The first one I saw was Mike Essa's drift car - a 2.5i with a turbo S54 swap. Practically nothing on that car was stock.
      06-02-2014, 11:04 AM   #10
pokeybritches
2006 BMW Z4M  [8.50]
      06-02-2014, 06:32 PM   #11
addictedto1
I have trevors old turbo setup, completely different software however.
      11-03-2014, 09:47 AM   #12
iTuneCars
Drives: Turbo Lexus
Question
Where are the progress pics?
