      02-02-2017, 08:41 PM   #1
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Fabspeed O2 bung spacers with inline-mini CATs
an interesting idea from Fabspeed.
They have a universal O2 bung c/w a mini CAT to fool the O2 sensor.
If i'm understanding this correctly it would let you run straight pipes or resonators and the mini CATs would look after the O2s
....anyone heard about these???
We've taken our O2 spacers a step further. The factory ECU compares the readings from a pair of oxygen sensors to measure the effectiveness of the catalysts. When a high-flow cat or catbypass pipe is used the exhaust gases reach the O2 sensor faster and uncleaned, leading to high chances to throw a CEL. Our O2 spacers retract the secondary oxygen sensors from the direct flow of gases, restoring the balance that the ECU requires when using aftermarket catalysts or catbypass pipes. The high quality built in catalysts scrub the exhaust to further reduce the chance of a CEL. Two fitting options and the two piece design allow for adjustment to get best possible fitment and results.
http://www.fabspeed.com/universal-o2...ic-converters/
yousefnjr6159.00
3GFX722.50
      02-03-2017, 01:59 AM   #2
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
Sneaky! They look pretty big, though!
      02-07-2017, 12:08 PM   #3
jns_e85
jns_e85's Avatar
74
Drives: '05 X3 2.5i, '06 z4M, '17 M2
Definitely interesting. I assume they could be threaded into existing 02 bungs as well?
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
      02-07-2017, 01:12 PM   #4
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Yes, I would think so, if there's room
      02-12-2017, 03:54 AM   #5
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Very interesting!
      02-12-2017, 04:17 AM   #6
pokeybritches
2006 BMW Z4M  [8.50]
Ordered before they're made illegal. I won't install them until July at the earliest.
      02-28-2017, 09:24 AM   #7
Cyclops
Cyclops's Avatar
So I was thinking of ordering these for my new headers that are currently on order. Can anyone tell me if I should buy the 90 or 45 degree?
2007 #1432 ///M Coupe Silver Gray - KW V3 Coilovers - AFE Intake - Strong-Strut Brace - Status Grupee Headers - Super Sprint Race Exhaust & Xpipe - 19" Avant Garde M359 - Stoptech 380 6 pot BBK - EPIC Motorsports Tuning ////////////2009 328xi M-Tech E91 manual 6spd
- Instagram ->@e91kiter
      02-28-2017, 09:32 AM   #8
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
It depends on the orientation of the header bungs and clearance.
      02-28-2017, 12:43 PM   #9
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Also, if there is a bung already there, then you may be able to screw straight in w/o the angle adapter.
      02-28-2017, 12:50 PM   #10
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Is this so you can run cat-less? interesting..
Powered by
      02-28-2017, 01:14 PM   #11
Cyclops
Cyclops's Avatar
There are bungs on the headers but I'm not sure how their position would relate to the body of the car once installed. I guess I'll just wait till they come in and order afterwards.
      02-28-2017, 02:05 PM   #12
tominizer
tominizer's Avatar
Drives: 2007 Z4M Roadster
I passed this onto a buddy of mine that knows way more than I do about BMW things. He basically said cats need heat to work, and that usually comes from exhaust flow. It might help enough to correct the signal a little bit but he's skeptical of them being a complete fix. I assume he's stating this because there's no flow at all in these. Any real world testing to back this up.
      02-28-2017, 02:27 PM   #13
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
good point....
With the small size of these, I'm not sure if it would take much to heat them up convected through the pipe itself.
I would think someone like Fabspeed would have tested before going to market with them.
      03-13-2017, 08:15 PM   #14
3002 tii
3002 tii's Avatar
2288
I bought a set of o2 simulators from ******, haven't installed yet but am hopeful considering these were the first sims to work for the n55 crowd
Follow for latest mods
      03-13-2017, 09:31 PM   #15
3GFX
3GFX's Avatar
Drives: 2003 BMW Z4 3.0i
Thanks for this post! I'll be saving up for these before my emission test next year!!!
      03-07-2018, 12:38 PM   #16
3GFX
3GFX's Avatar
......annnnnnnd here we are.
These or O2 sims?
      03-07-2018, 12:46 PM   #17
Cyclops
Cyclops's Avatar
These or O2 sims?
I'm currently test a generic set, however, I damaged one pre and post cat sensor so waiting for a replacements to arrive. Will post a full write up once complete.
http://www.zpost.com/forums/showpost...77&postcount=5
3GFX722.50
      03-07-2018, 12:53 PM   #18
PLCZ4MC
Proud E86M Owner
PLCZ4MC's Avatar
Drives: 07 Z4M Coupe Monaco Blue
This look very interesting to run straight S pipes and headers without cats, but I wonder if the Z will pass smog check in California x-x
2007 Z4///M Coupe Monaco Blue (Weekend + Track)
2018 S1000RR San Marino Blue Wrap (Weekend + Commute)
2016 Honda CR-Z EX Jet Black (Daily Commute)
2008 Kawasaki ZX6R Plasma Blue (SOLD)
2008 Z4///M Roadster Space Gray (SOLD)
      03-09-2018, 06:03 AM   #19
3002 tii
3002 tii's Avatar
2288
If anyone wants a pair I have a set I’ll sell at discounted price. PM me...
