05-06-2015, 12:24 PM | #1 |
Rep 321
Soft top question
Greetings,
Pulled my 07 M Roadster from the garage after winter storage. Car was stored with the roof closed, car cover, and battery tender. Strange thing is going on with the soft top. It goes up and down without difficulty. It disengages and engages the cowl of the windshield without difficulty. However, when the roof is retracted it stops just short of being flush to the rear shelf behind the seats and the red light stops blinking to indicate that it is retracted sufficiently; even though it is not. I bypassed the hydraulic motor and manually lowered the top, but it still stopped short of the rear shelf. I put some pressure on the top to see if I could move it to the "locked" position flush with the shelf, but it wouldn't budge. I have read multiple threads and Skipkiller's explanations for roof failures. It doesn't sound like a problem with the motor and if the compartment floor switch was bad, it wouldn't lower the top at all. I have checked the the shelf trunk to make sure it is at it's lowest position. In my Google search I found only one thread with this same problem. It was in the UK and it ended in a "black hole" with the person never updating the solution. The two things I'm thinking are that maybe the compartment switch has become glitchy or the switch arm is slightly bent...or the roof has suddenly decided to fold in such a way as to make the roof stop prematurely? Kind of scratching my head on this one...any help or suggestions would be welcome. Thanks in advance! |
05-06-2015, 04:07 PM | #3 |
Rep 525
This definitely points to some sort of obstruction, but odd that the red light extinguishes as per normal cycle completion. I'd be inspecting very closely for some stray protrusion - organic or inorganic. Otherwise, when auto-retracting, have you tried to assist the process at the end of its travel by pushing a bit as it descends into its cavity - like spotting a weightlifter?
05-06-2015, 04:16 PM | #4 |
Rep 2,138
Drives: Me
If the 'Compartment Floor' or shelf was up, then the top would not retract.
As Kimo says, do a visual for something obvious, and try lubricating the joints on the frame. The frame might be binding a little. This happens (top not going all the way down) more times than you think. Since you have a 2007, you may or may not have the 'topdown' lock, as BMW deemed it unnecessary and it (the lock) was deleted later on, so if it sticks up an inch it is not a really a big deal. It just looks odd. |
05-06-2015, 05:20 PM | #5 |
Rep 384
Also, there is a "Grabber" in the middle of the back deck that is supposed to grap and lock down the roof when it reaches the full open position. You should see a set of hooks about where that empty space under the roof in the photos that grap the roof and pull it locked down.
Maybe that is not grabbing and locking for you.
The Internet said it. I believe it. That settles it!
05-06-2015, 06:33 PM | #6 |
Rep 4,057
I know this is unlikely to be the cause but if it was very cold that day the roof may not operate properly. A buddy of mine experienced this but it was during winter on a cold day in his unheated garage . I know that's a long shot in this case but I'll throw it out there anyway.
05-07-2015, 06:03 AM | #7 |
Rep 321
Thanks everyone for giving me some suggestions!
1. I've checked the shelf position and it appears normal. 2. Did a check for any obvious obstruction...didn't see anything, but will continue to look. 3. Will try that suggestion about guiding the roof as it descends. 4. Will lubricate the joints, 5. Will also investigate the "grabber" in the middle of the back deck. I'm hoping I can get it to close flush because I don't like it looking "odd" as it sits right now. |
05-07-2015, 06:05 AM | #8 | |
Rep 321
05-07-2015, 06:09 AM | #9 |
Rep 525
Further to my last, check carefully that the fabric is folding as designed. A rogue pleat could bind the whole retraction cycle - and, like electricity, once it folds that way once it will always seek the path of least resistance until corrected.
05-07-2015, 07:05 AM | #10 |
Rep 4,057
Och the deadly rogue pleat - bonnie wee scourge of the Scotish kilt wearer for many a generation!
Huz-Z
05-07-2015, 07:21 AM | #11 |
Rep 525
05-07-2015, 09:00 AM | #12 | |
Rep 321
