07-24-2011, 08:20 PM | #1 |
Rep 1,461
Removing The Oil Pan On A Z4
has anyone evr removed their oil pan on your z4..I busted the oil pin, and now I have to remove the oil pan to get the pin out,,anyone ever done this..help is much appreciated.
07-24-2011, 08:54 PM | #2 |
Rep 245
Drives: fairly quickly.
Here you go, see the attached pdf.
"It will not have enough power until I can spin the wheels at the end of a long straight in top gear."
-Mark Donohue |
07-24-2011, 09:18 PM | #3 |
Rep 1,461
Oh dude thanks very very much I was feeling like the village idiot till I read that it broke because it was supposed to if i gave it to much of a turn....thanks bro.
05-21-2019, 11:04 AM | #6 |
Rep 2,706
Doesn't really tell you anything you didn't already know.
The big task is supporting the engine from above while you take down the subframe below. I have a thread on here somewhere. I used a piece of aluminum structural tube and nylon ratchet straps to support the engine when I did my OPG. Mind you I had most of the ancillary parts off my motor at the time. Here is my thread. Not sure why I am seeing some pics upside down. https://www.zpost.com/forums/showthread.php?t=1208850
