      02-10-2014, 09:38 AM   #1
Gt4
Gt4's Avatar
Drives: 2006 E46 M3 Estoril blue 6mt
USD 1,000.00
      02-11-2014, 01:11 PM   #2
p1nk50ck
HNIC
Drives: Z4M Coupe
oh man... i missed your last sale. i need these in my life.
were these set up for fitment in the front, or rear?
      02-11-2014, 05:37 PM   #3
Gt4
Gt4's Avatar
I used them as front wheels with 18x10 et26 rear but they can also be use as rear depending on car setup.
They will make a good back up as track wheel for someone.
      02-12-2014, 09:44 AM   #4
p1nk50ck
HNIC
Drives: Z4M Coupe
only good for backup wheel? they look pretty clean from the pictures. dents dings?
      02-12-2014, 10:50 AM   #5
Gt4
Gt4's Avatar
They are clean, lips are freshly polished
Back up wheels because I only have 2.
      02-18-2014, 06:52 PM   #6
p1nk50ck
HNIC
Drives: Z4M Coupe
are the centers factory painted? i'm wondering if i pick these two up, if i'll be able to match another set, or if i should just take the centers off, and get everything repainted.
also painted, or powdercoated?
did you use spacers with these on the front?
      02-19-2014, 10:05 AM   #7
Gt4
Gt4's Avatar
I painted them myself last year. I used Dupli-color wheel coating HWP102 - Graphite
http://www.duplicolor.com/products/wheelCoating/
But it's really easy to remove the centers and put them back on if you want to go with a custom color. Just need a torque wrench and torque back to 22lb-pi. The procedure to torque properly can be found here:
http://www.ccwheel.com/technical-repair.php
No need for spacer, lot of space between the tire/rim and strut/spring when using coilover. Also fit under the fender with proper alignment and tire size. And I was also able to use them without spacer with my huge Performance Friction BBK.
