03-11-2014, 07:15 PM | #1 |
Rep 3,939
Rubber/weather trim around windshield.
Folks,
One of the DIY's that I'd like to tackle one of these days is the replacement of the rubber trim around the windshield. The one on my car is not flat/flush against the roof or a-pillars (it's a little lifted), making me wonder if this is indeed the way it's supposed to sit, or if it should be nice and flush. The reason I have doubts is that it doesn't seem too worn out or hardened, like the cowl cover did before I replaced it. Has anyone done the job and can this rubber trim be replaced with the windshield on the car? Or does it need removal? Thanks!! |
03-11-2014, 08:04 PM | #3 |
Rep 384
And here is the best price I've found for it -http://www.rmeuropean.com/Part-Numbe..._E095124A.aspx
The Internet said it. I believe it. That settles it!
03-12-2014, 07:33 PM | #5 | |
Rep 231
edit-- it is $28 |
03-12-2014, 08:12 PM | #6 |
Rep 3,939
Nice…thanks!
The one on my car seems fairly new…I almost get the feeling that the prior owner replaced it but didn't install it properly. Any recommendations? Should I try to push it into the groove and see if it goes flush? I'm not sure if he used any silicone adhesive or not…not sure what to expect. |
03-12-2014, 08:56 PM | #7 |
Rep 219
Drives: 2007 BMW Z4 M Coupe
Garage List 2000 Volve S70 se [0.00]
2000 Triumph Dayton ... [0.00] 2007 Husqvarna TE250 [0.00] 2002 Ducati Monster ... [0.00] 2007 BMW [0.00] |
Thanks! Mines in tact... But scored up/gouged on one side. I've thought about replacing, but assumed it would be too expensive.
03-12-2014, 10:55 PM | #8 |
636
Rep 3,124
There's no adhesive required.
It really doesn't do anything but cover the edge of the windshield for looks. If it's in good shape and doesn't seem like it's going to crack, I would suggest pulling it off and making sure there's nothing lodged under it. Clean everything up nicely and put it back on. It hooks around the edge of the windshield and then the outer edge just pops down into the slot.
03-13-2014, 07:21 AM | #9 | |
Rep 3,939
03-13-2014, 07:41 PM | #10 |
Rep 3,939
Could someone please snap a quick shot of the rubber trim specially on the of the glass that mates to the roofline? If possible, take a picture from the side or slightly angled from behind the trim (from the back of the car)…I'm interested to see how it's supposed to sit.
Thanks! |
03-14-2014, 02:22 PM | #12 |
Rep 262
I had mine replaced under warranty by my local dealer. It took them two full days to complete the repair and yes that's with the part already received! They still managed to scuff the passenger side leather door card....go figure. Of course I was told the damage was there when I brought my car in.....yeah, right. DIY is the only way to go....I wish I would've gone the route you're going.
03-16-2014, 01:59 PM | #13 | |
Rep 162
But also not an easy DIY - careful with that windshield! |
07-29-2014, 12:43 PM | #14 |
Rep 178
I've noticed the center area right above the rearview mirror starting flapping and lifting with "spirited" driving." I think this was replaced 2 years ago prior to the car's purchase, but wondering if it was replaced incorrectly.
Given the cost I'm thinking about just replacing it, but if I push down hard and go along the entire roof, it seems to sit back down into the groove. But my area has been 100 degree plus, so maybe its becoming too pliable before I drive "spirited." What makes this a hard DIY? |
07-29-2014, 02:42 PM | #15 |
636
Rep 3,124
I found that part to be easy. Getting the wiper arms off the replace the cowl was a bit of a faff.
If it's just flapping, but otherwise not falling apart, I would pull that section up and squirt some silicone caulk under it.
07-29-2014, 02:46 PM | #16 |
Rep 178
Would that make it very difficult to remove if it needed to be replaced? What kind of caulk would you recommend? I don't want to have it too permanent and cause more damage long term.
07-29-2014, 03:12 PM | #17 |
636
Rep 3,124
Just general purpose clear silicone.
The cheaper the brand, the easier it will be to clean up when you replace the part. It won't really make it hard to get off. If it starts to decompose it'll come off in chunks anyways. You'll just have to peel the caulk off with your fingernails. Use it sparingly.
