      07-24-2013, 10:39 AM   #1
Devious21
Devious21's Avatar
No_Country
38
Drives: 2006 Z4M
Cold Start - Engine cranks 5-10 times before starting.
When the car is warm, it starts right up. But each morning, I have to keep on it to start. It's cranking strong and I just had the battery replaced a month or two ago but just refuses to start up quickly.
Once started, I don't experience rough or dipping idle like in the some of the other threads I found on zpost.
I had one of my shops take a look a while back but they couldn't reproduce it (car wasn't cold) and they didn't find any codes. Since then, it seems to be slowly getting worse.
31k on odometer and haven't had inspection 2 yet (hasn't prompted me yet). Only thing I've done is added techron last two fill ups. So far no noticeable improvement during cold start. I'm going to be doing headers and exhaust soon and I want to make sure I don't have any underlying issues outstanding before I go making a bunch of changes.
|Evolve Airbox - Euro Headers - Strömung Exhaust - H&R Coils - 19" BBS CH-R|
      07-24-2013, 10:42 AM   #2
cyberkaa
:facepalm:
cyberkaa's Avatar
Drives: 2x 2003 332i, 2020 M2CS
I'd start with a fuel pressure test. There's an internal check valve that should maintain pressure to aid in starting. If the pressure bleeds off too quickly it can cause long cranks.
-Kalim (klx photo studio)
Originally Posted by M_Truong
Donuts make you go nuts
      07-24-2013, 12:03 PM   #3
R0ME0
"The Midas Touch"
R0ME0's Avatar
519
Drives: F87 LBB ///M2
2017 M2  [10.00]
2008 Z4M - SOLD  [0.00]
I had the same issue check out my thread:
http://www.zpost.com/forums/showthread.php?t=826328
The dealer replaced the following: MAF Sensor, Fuel Pump, and T-Shape Idle Regulating
Valve
Seemed to have been the T-Shape Idle Regulating Valve. Now that its replaced it no longer has been an issue.
Hope that helps!
      07-24-2013, 12:41 PM   #4
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Do you hold the key in position 1 while the fuel pump charges the system?
      07-24-2013, 12:54 PM   #5
Devious21
Devious21's Avatar
No_Country
38
Drives: 2006 Z4M
Was just reading about that in the other threads. Going to try it tomorrow morning.
Right now, I do not.
      07-24-2013, 03:02 PM   #6
ajw45
Drives: Z4M Coupe
I have a similar issue but haven't found any faults recorded in the ECU. Did the shop replace those based on reported faults or just the manual diagnosis?
Valve
Hope that helps!
      07-25-2013, 01:38 PM   #7
Devious21
Devious21's Avatar
No_Country
38
Drives: 2006 Z4M
Tried it this morning. It might have started slightly faster (8 cranks instead of 10-12) but not much. I'll continue to try it each morning to see if there's a noticeable difference.
Valve
Hope that helps!
Was your issue actually starting or more rough idle AFTER start. As mentioned, I'm not experiencing any rough idle, just trouble starting.
Let me know.
