      05-05-2013, 05:07 PM   #1
G80indy
Save the Manuals
G80indy's Avatar
Drives: Z3, E46, G80
AA software for S54 Z4M, anyone?
AA site page
Anyone get up the nerve yet to do this one ??
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT
2000 Z3 Conforti, 5MT
      05-08-2013, 10:27 AM   #2
pal
pal's Avatar
433
Drives: Z4 M Coupe
I ordered the software today and will report back with subjective feedback in the next couple of weeks (doing the Glen on May 18-19 and Pocono Long on May 24). Objective dyno data will be later in the year.
      05-11-2013, 02:35 AM   #3
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Yes, it's already been done. I was the first on the forums to get the tune and there are several others that have also gotten the tune for their Z4Ms. Check out the thread I made for more info:
http://www.zpost.com/forums/showthread.php?t=449998
      06-28-2013, 09:17 PM   #4
mlawfl11
Drives: 2007 M Coupe
I have it. Great tune.
Current: 07 Z4M Coupe, Imola Red Ext, Sepang Bronze Int, Alum Trim, Nav, Sat, CS.16 19", RE Exhaust, K&N Filter, AA Tune, Stubby, 12" Kicker Sub
Previous: 07 Z4M Coupe, Interlagos Blue Ext, Black Nappa Int, Alum Trim / 09 z4 sDrive35i, Silver - Black Leather -Premium Radio
      07-04-2013, 10:59 AM   #5
Urluz3n
Lackey
Drives: 07 BMW M Coupe
Okay so you got the tune. Do you have headers or other mods that the tune helped with gains?
      07-04-2013, 01:23 PM   #6
mfanatic325
///M-fanatic
Taiwan
193
Tune alone, I went from 266rwhp and 235rwtq stock baseline to 295rwhp and 243rwtq on the same dyno, different days, similar ambient temps.
There are plenty of others that have the same tune, but over the last two years or so, nobody has been able to do another "stock vs. tuned" dyno (provided that the ECU had enough time to fully adapt)
My highest yield was with additional bolt-ons at the time:
AA NA tune for 91 octane
RPi induction system (scoop + drop-in filter)
JVT headers
SS uncatted section1
SS x-pipe
SS race mufflers
And that put out 310rwhp and 256rwtq peaks; again, on the same dyno with similar ambient temps.
Edit: On a side note, I "extracted" the AA tune in lieu of flashing in a new tune for my VF570 SC kit about two months ago. I do miss the smoothness and overall driveability of the AA tune, but it's kind of an apples to oranges comparison since I now have much higher-flowing fuel injectors with this SC kit and the characteristics of fueling are drastically different from stock.
Edit2: Before I had VF look over my kit for any air leaks, etc. my kit put out 370rwhp and 300rwtq again on the same dyno.
It should now be around 450rwhp and 320rwtq.
RatedMRoadster's VF570 put down 472rwhp and 330rwtq on a DynoJet for reference.
      07-04-2013, 03:04 PM   #7
beta
Drives: 2006 M Roadster
When did you get your wheels? Light weight wheels could be worth around 10hp.
      07-04-2013, 03:29 PM   #8
mfanatic325
///M-fanatic
Taiwan
193
The dyno I have most access to is a DynaPack which connects directly to the hubs and foregoes wheel/tire combo, so it is out of the equation so to speak. In any case, I doubt wheel/tire shows up on dyno. It'll make a bit of difference in real-world application but I always discount stuff like that for consistency sake or treat them as neglibles.
But to answer your question, I've had these same wheels since like early 2011
      07-04-2013, 04:21 PM   #9
beta
Ah, in that case it has no bearing on your dyno numbers.
If you follow the link I posted you'll see that it does (on a traditional dyno, not a hub dyno). If you search around you'll see many similar tests showing a small increase (10hp or so) from lighter wheels, here's another example.
      07-06-2013, 09:07 PM   #10
Urluz3n
Lackey
the reason i am checking tunes is yesterday I installed my new FAB Speed cat-less headers. After about 30 miles i got my CEL. I am wondering if the AA tune will fix the CEL?
      07-07-2013, 02:43 AM   #11
mfanatic325
///M-fanatic
Taiwan
193
The AA tune can get rid of CEL from headers, but depending on your state's emissions/smog laws and procedures, you may have trouble passing.
      07-10-2013, 04:50 PM   #12
Urluz3n
Lackey
Dude I live in Florida no emission testing here!
