06-07-2011, 01:42 PM | #111 |
Rep 231
I found it took a little finagling to get it to line up. I attached mine with sheet metal screws into the bumper cover. I pre-drilled holes in the lip and then match drilled a pilot into the bumper cover while pushing or pulling to the location I wanted. The only place I had a bit of a problem was right at the inner portion of the "fang". There wasn't quite enough material to get it exactly right and still install the existing fastener so it did sit an eighth of an inch or so recessed at those points. But it still looked fin.
That is until some idiot (me) smacked a curb this weekend. It's off now deciding whether I can repair it or not.
06-07-2011, 01:58 PM | #112 | |
Rep 416
06-07-2011, 04:43 PM | #113 | |
Rep 361
I'll investigate and see what's the matter. I test fitted the first form/mould on 3 separate Z4 M(s) and fitment was good. I did noticed not all 3 bumpers were 100% alike; fitment varied slightly between the cars using the same form. Is there a balanced medium between those two senarios you mentioned? |
06-07-2011, 06:02 PM | #114 |
Rep 316
I had the same issue with mine. The ends of the lip dont line up quite right. The curve of the lip, also does not quite match the curve of my bumper. To use the factory bolts in the outside portion under the bumper cover, I was forced to "persuade" the lip a little bit. Even with all this, in the end, it looks pretty good, as long as you dont run from side to side to see that the end points dont match up right.
06-07-2011, 07:36 PM | #115 | |
Rep 457
If it were close enough to slightly persuade the piece into place I'd be ok with it but it'd be way too much stress on the piece and my bumper IMO with the amount of difference there is. Anyway I'll snap some pics asap to give a better understanding. Thanks for the response..
06-07-2011, 08:53 PM | #116 | |
Rep 2,431
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm Gone:z4m, boss 302, c6 z06, m6,z3m |
06-17-2011, 12:40 PM | #117 |
Rep 361
1. krnnerdboy -Picked Up
2. shimmy09 -Picked Up 3. barryb97 -Shipped 4. NickyC -Shipped 5. z4murder (in for 10+) -Shipping Info/Payment requested 6. vicj (in for 10+) -Shipped 7. MIKe86 (in for 10+) -Shipped 8. Hdoan86 -Shipping Info/Payment requested 9. eunosracr (in for 10+) -Shipping Info/Payment requested 10. BookerM3 (in for 10+) -Shipping Info/Payment requested 11. Jumbosock with a 3 pointer to make it 10! (x 2) 12. wacaw325 (in for 10+) 13. JDN34 14. jair_onsa(in for 10+) 15.CobraR1339 16. Shec44 (in for 10+) 17. nofear 18. z4-villalona 19. MochaV 20. McWong 21. 850tgul 22. Little C 23. MPOWER78 24. Blind32 25. Steve335 26. johanness 27. Recklessz4 28. david_lm 29. Finnegan ____________ 30. S54B32M 31. E86M C |
06-18-2011, 08:08 PM | #119 |
Rep 123
Hey Steve. How long do u think it'll take for me to get mine? I'm at spot 25 btw. TIA
2007 E92 335i - Delivered on 4/24/2007 Montego Blue, Sports Pkg, 6MT, Brushed Trim |
06-19-2011, 10:59 PM | #120 | |
Rep 361
Steve REMAINING ORDERS: 1. Hdoan86 -Shipping Info/Payment requested 2. BookerM3 (in for 10+) -Shipping Info/Payment requested 3. Jumbosock with a 3 pointer to make it 10! -Shipping Info/Payment requested 4. wacaw325 (in for 10+) 5. JDN34 6. jair_onsa(in for 10+) 7.CobraR1339 8. Shec44 (in for 10+) 9. nofear 10. z4-villalona 11. MochaV 12. 850tgul 13. MPOWER78 14. Blind32 15. Steve335 16. johanness 17. Recklessz4 18. david_lm 19. Finnegan ____________ S54B32M E86M C |
06-24-2011, 06:07 PM | #122 | |
Rep 361
Thanks for asking, Steve REMAINING ORDERS: 1. Jumbosock with a 3 pointer to make it 10! 2. wacaw325 (in for 10+) 3. JDN34 4. jair_onsa(in for 10+) 5.CobraR1339 6. Shec44 (in for 10+) 7. nofear 8. z4-villalona 9. MochaV 10. 850tgul 11. MPOWER78 12. Blind32 13. Steve335 14. johanness 15. Recklessz4 16. david_lm 17. Finnegan |
06-24-2011, 07:11 PM | #123 | |
DHS
204
Rep 4,011
2023 BMW M4 2016 X3 |
07-03-2011, 06:05 PM | #125 | |
40
Rep 1,481
If so....and if there wasn't an added support frame bridge built on the mold backside, its possible your mold is heat cycling and warping as you make parts. Either that, or you need to add less MEKP % to let the parts fully cure in the mold before de-molding. Best bet is to post cure the part while still in the mold with heat lamps overnight. THEN de-mold . Cheers,Vinny |
07-05-2011, 06:55 AM | #126 |
Rep 1
Hey all.
Is this still available, im based in london england and would be keen to get hold of this for my z. Is it possible to ship to the UK and if so how much?? |
07-06-2011, 06:01 PM | #127 | ||
Rep 361
REMAINING ORDERS:
1. Jumbosock with a 3 pointer to make it 10! -- (x2) Payment/Shipping Info Requested 2. wacaw325 (in for 10+) -- Payment/Shipping Info Requested 3. JDN34 -- Payment/Shipping Info Requested 4. jair_onsa(in for 10+) 5.CobraR1339 6. Shec44 (in for 10+) 7. nofear 8. z4-villalona 9. MochaV 10. 850tgul 11. MPOWER78 12. Blind32 13. Steve335 14. johanness 15. Recklessz4 16. david_lm 17. Finnegan I didn't forget about you. You're on the second list. Quote:
Hi Vinny, Sounds like you've worked with composites before. Two of the moulds were made using polyester resin and 10+ layers of fiberglass cloth. It's very strong and fully cured so I hope it's not distorting. I'll check them against the original plug. I've switched to epoxy resin since so there's no need for MKEP catalyst or any issues related to it. I give it a few days for the parts to cure before removing it from the moulds. I'll see if it needs to set in the mould for longer. Thanks for the tips Steve Quote:
Let me know if there's a shipping company with reasonable rates if you know of one. Thanks. |
07-06-2011, 06:48 PM | #128 | |
40
Rep 1,481
You mentioned cure time on the mold. Most of us give up to 2-3 weeks for post cure WITH the assistance of heat....whether the solar heat or heat-lamps or heat blankets. Even Epoxy manufacturers will require it if you ask them. Its a necessary evil in the craft. Almost every mold will move if its receiving its cure cycles by molding parts instead of a post heat cure with the plug still in place. You might be able to save the mold by re-inserting your plug or parent part and then adding glassed in beam supports to the mold backside and then placing it all out in the sun for a week or so. Let me know if you need more help on the subject. Cheers,Vinny |
07-07-2011, 04:34 PM | #129 |
Rep 99
Drives: 2007 Z4 M Coupe
I'd like one of these. Let me know when you do your next batch!
07-07-2011, 04:45 PM | #130 |
Rep 1,739
Drives: 2008 Z4MC
Can someone please confirm exactly how much this lowers the chin? (i.e. distance to ground) I'm on H&R springs and don't want to rip this thing off on the first pothole / speed bump I come across. Thanks!
07-08-2011, 04:47 PM | #131 |
Rep 78
I dont have the measurment for you, but I also have H&R springs with this lip. I've had it on for about a month and I have very lightly scraped 2-3 times on steep driveways. For the most part I have not had any issues, you just have to be careful!
07-11-2011, 01:47 PM | #132 | |
Rep 361
REMAINING ORDERS:
1. jair_onsa(in for 10+) -Shipping Info/Payment requested 2.CobraR1339 3. Shec44 (in for 10+) 4. nofear 5. z4-villalona 6. MochaV 7. 850tgul 8. MPOWER78 9. Blind32 10. Steve335 11. johanness 12. Recklessz4 13. david_lm 14. Finnegan Quote:
Will do. |
