      05-11-2014, 08:20 AM   #1
Krypptic
Drives: E92M, GT3
Valve Adjustment and what else?
Bringing in the car for a valve adjustment, replacing rod bearings with new treated ones with arp bolts. What else should I upgrade or check out while completing this job?
      05-11-2014, 08:51 AM   #2
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Camshaft bolts need to be checked I believe and they should replace your gasket while there. Oil change recommended. Most importantly as them to record before and after measurements
      05-11-2014, 04:33 PM   #3
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
When time comes, I'm gonna have the exhaust hub upgraded to the C300 version from Dr vanos. Costly but a great piece of mind.
      05-11-2014, 05:31 PM   #4
Krypptic
Drives: E92M, GT3
Excuse my ignorance, but what measurements I am asking for?
coh661191.00
      05-11-2014, 05:38 PM   #5
dorifto88
Drives: 88 Nissan Pathfinder
id assume the valves when they are adjusted?
      05-11-2014, 06:32 PM   #6
itdnwiwbp
Drives: 330iZHP
Is the cryogenically treated hub not worth the extra $100? Will you be upgrading the oil pump disk at well?
      05-11-2014, 07:05 PM   #7
Jumbosock
Jumbosock's Avatar
76
I don't know anything about cryogenic treatments so I'd rather buy the beefed up C300 version. With this beefed up version you don't need to upgrade the disc because the beefier tabs fit the OEM disc more snugly.
      05-11-2014, 08:43 PM   #8
itdnwiwbp
Drives: 330iZHP
Ah. Good info. Thanks, David!
      05-11-2014, 09:19 PM   #9
ZStig
279
yeah the spacing or whatever
      05-11-2014, 11:41 PM   #10
StickMon
StickMon's Avatar
Drives: 2006 MR
The upper timing chain guide that tensions the chain.
It's plastic, about $15, and there's M3 threads showing many of them worn through.
I have the C300 hub and I'm very near pulling the trigger on a rebuilt Vanos and doing the chain guide and tensioner.
(102k miles. Figure the Vanos and chain guide have had a good run.)
